1C9A”BC
IN
AEBTI S
N EATNSDAENNDC E
LN
OC
SU
LO
RS
EU
S RES
19’’ desktop enclosures
Product overview
C19DE
Sturdy lightweight 19” enclosures designed to
accept ‘full-width’ 84E subracks and standard
19” units.
Heights from 2U up to 9U
Constructed from 1mm steel
Supplied with front tilt-feet, rear fixed feet
Ventilation slots in base and rear panel
Recessed side handles for comfort and easy
transport
• Supplied flat-packed
• Open front design
• Front options ordered separately
U
W I DT H
HEIGHT
LENGTH
2U
489mm
131.5mm
330mm
C19DE2450
2U
489mm
131.5mm
450mm
C19DE3330
3U
489mm
176mm
330mm
C19DE3450
3U
489mm
176mm
450mm
C19DE6330
6U
489mm
306mm
330mm
C19DE6450
6U
489mm
306mm
450mm
C19DE9450
9U
489mm
443mm
450mm
W
H
PA R T N O .
C19DE2330
1C9A”BC
IN
AEBTI S
N EATNSDAENNDC E
LN
OC
SU
LO
RS
EU
S RES
S P E C I F I C AT I O N
428
Materials
Shell 1mm thick steel
Handles ABS
Legs ABS
Standard colours
Shell: epoxy paint graphite grey
Handles: black similar to RAL 9004
Legs: dark grey similar to RAL 7016
Standard unit includes
Top and bases covers
Two side panels
One rear panel
Four feet
19” mounting brackets
Handles
Mounting hardware
Options
19" front panels
K E Y F E AT U R E S
Lightweight
Sturdy
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
L
1 9 ” C A B I N E TS A N D E N C LOS U R E S
ACC E SS O R I E S
19” Aluminium front panel
• 3mm thick aluminium, clear anodised
S TA N DA R D F R O N T
VENTED FRONT
U
HEIGHT(MM)
CAX19SPS1
CAX19VPS1
1U
43.6mm
CAX19SPS2
CAX19VPS2
2U
88.1mm
CAX19SPS3
CAX19VPS3
3U
132.5mm
CAX19SPS4
CAX19VPS4
4U
177.0mm
CAX19SPS5
CAX19VPS5
5U
221.5mm
CAX19SPS6
CAX19VPS6
6U
265.9mm
CAX19SPS9
CAX19VPS9
9U
399.2mm
VENTED FRONT
U
HEIGHT(MM)
CAX19SPA1
CAX19VPA1
1U
43.6mm
CAX19SPA2
CAX19VPA2
2U
88.1mm
CAX19SPA3
CAX19VPA3
3U
132.5mm
CAX19SPA4
CAX19VPA4
4U
177.0mm
CAX19SPA5
CAX19VPA5
5U
221.5mm
CAX19SPA6
CAX19VPA6
6U
265.9mm
CAX19SPA9
CAX19VPA9
9U
399.2mm
19” Steel front panel
• Manufactured in steel
• Powder coated (RAL 7016)
• M6x15mm screw, PA washer, M6
caged nut
PA R T N O .
DESCRIPTION
CAX000001
Attachment set (pack of 4)
1C9A”BC
IN
AEBTI S
N EATNSDAENNDC E
LN
OC
SU
LO
RS
EU
S RES
Attachment set
Vers 1
429
很抱歉,暂时无法提供与“C19DE2330”相匹配的价格&库存,您可以联系我们找货
