CBHEX1-PI4-BK
CBHEX1-PI4-BK
    CAMDENBOSS
    CAMDENBOSS - CBHEX1-PI4-BK - Plastic Enclosure, Raspberry Pi4, Hex-Box IoT, ABS, 45 mm, 130 mm, 146 ...
CBHEX1-PI4-BK 数据手册
V E R S AT I L E I O T A N D S E N S O R E N C L O S U R E S 268 HANDHELD DIECASTCASES ACCESSORIES 292 UNIVERSAL ENCLOSURES 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES 342 DESKTOP AND INSTRUMENT CASES Call our sales team today on 01638 716101 or visit www.camdenboss.com/Hex-Box-IoT-enclosure Hex-Box IoT enclosure Product overview This UK manufactured Hex-Box has been designed with customisation and user flexibility at heart. The 100% recyclable housing features six self-retaining panels which you can mix and match to suit your requirement. The enclosure offers huge connector access and air flow benefits, ideal for industrial IoT settings. The design features and modern aesthetic create the perfect enclosure for walls (when paired with the wall mount bracket) or desktops (when paired with the rubber feet), each sold separately. Key features PCB mounting in the top and base Six bosses in the top, four in the base with Raspberry Pi mountable footprint Number index in base 348 Aids wall mounting DEVELOPMENT BOARD ENCLOSURES Self-retaining removable end panels Allows cable entries from all sides. Panels can be easily customised and are available as either solid or vented 367 Guide for cable knock-out VERSATILE IOT AND SENSOR ENCLOSURES Aids customisation with alignment of wall mount bracket Smooth bevelled lid with flat top Suitable for a 2.5” screen and perfect for digital printing 370 CUSTOM SIZED ENCLOSURES PCB positions R A N G E S P E C I F I C AT I O N STANDARD UNIT INCLUDES MATERIALS COLOURS UL94-V0 ABS Top UL94-V0 ABS BZP (Bright Zinc Plated Steel) Grey RAL7047 Black RAL9005 White RAL9003 RoHS compliant OPERATING TEMPERATURE -10°C to +80°C SCREW TORQUE 122.2mm Hex A/F TOP 121.8mm Hex A/F When using a 1.6mm thick PCB, you will need No.4x6.5mm self-tapping screws (not supplied) Top Standard Test Result Test report EN 62262 Impact test IK07 TR112 BS EN 60529 IP code Base Vented: IP30 TR110 Solid: IP40 Pozi CSK screws 0.3Nm Country of origin Great Britain (GB) PURCHASING Commodity code 3923101000 INFORMATION Weight 120g Enclosure type Versatile sensor and IoT enclosures OPTIONS MAXIMUM PCB DIMENSION BASE Maximum PCB dimension Screws PCB MOUNTING POSITION Maximum PCB dimension P L AST I C E N C LOS U R E S Base COMPLIANCE TEST RESULTS 377 Base, top, 6 x panels, 3 x 16mm thread forming (Pozi CSK) screws Enclosure dimensions E X T E R N A L ( L x Wx H ) I N T E R N A L ( L x Wx H ) WA L L T H I C K N E S S 146 x 130 x 45 mm 122.5 x 125.5 x 34.5 mm 2.5 mm For alternative colours and materials MOQs will apply Potential industries / applications Industrial IoT, smart home, smart office, retail, speaker/ alarm buzzer, H L W meeting room device, network equipment, environmental sensor equipment, development board electronics. +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 V E R S AT I L E I O T A N D S E N S O R E N C L O S U R E S Call our sales team today on 01638 716101 or visit www.camdenboss.com/Hex-Box-IoT-enclosure 268 C H O O S E YO U R E N C L O S U R E C O M B I N AT I O N OPTION DESCRIPTION GREY (GY) B L AC K ( B K ) WHITE (WH) Option 1 1 x enclosure and 6 x solid panels CBHEX1-60-GY CBHEX1-60-BK CBHEX1-60-WH Option 2 1 x enclosure, 5 x solid panels and 1 x vented panel CBHEX1-51-GY CBHEX1-51-BK CBHEX1-51-WH Option 3 1 x enclosure, 4 x solid panels and 2 x vented panels CBHEX1-42-GY CBHEX1-42-BK CBHEX1-42-WH Option 4 1 x enclosure, 3 x solid panels and 3 x vented panels CBHEX1-33-GY CBHEX1-33-BK CBHEX1-33-WH Option 5 1 x enclosure, 2 x solid panels and 4 x vented panels CBHEX1-24-GY CBHEX1-24-BK CBHEX1-24-WH Option 6 1 x enclosure, 1 x solid panels and 5 x vented panels CBHEX1-15-GY CBHEX1-15-BK CBHEX1-15-WH Option 7 1 x enclosure and 6 x vented panels CBHEX1-06-GY CBHEX1-06-BK CBHEX1-06-WH Option 8 1 x enclosure, 2 x customised solid panels to accommodate Raspberry Pi4, 2 x solid panels and 3 x vented panels CBHEX1-PI4-GY CBHEX1-PI4-BK CBHEX1-PI4-WH HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES 292 UNIVERSAL ENCLOSURES 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES Desk mount accessory 342 DESKTOP AND INSTRUMENT CASES Rubber feet Product overview 348 The six rubber feet (CBHEX-FEET) turn your Hex-Box IoT Enclosure into a tabletop enclosure. Simply push the feet into the holes in the base of the Hex-Box IoT Enclosure. DEVELOPMENT BOARD ENCLOSURES RUBBER FEET (6PCS) 367 VERSATILE IOT AND SENSOR ENCLOSURES CBHEX-FEET Wa l l m o u n t accessory 370 CUSTOM SIZED ENCLOSURES Product overview C i r c u l a r Wa l l M o u n t B r a c k e t Transform your Hex-Box IoT Enclosure into a wall mountable enclosure with the Circular Wall Mount Bracket. This revolutionary circular mounting bracket is packed full of mounting options and offers seamless and discrete mounting to retain the modern aesthetic look of your housing, whilst gaining additional functionality. Key features 2 x keyhole mounting slots Allow for quick and easy wall mounting Raised rib stand-offs Help with stability of the enclosure on uneven walls 2 x sets of UK single gang back box mounting points In two off centre orientations 25mm cable entry knock-out for cable management Customisation required to the enclosure base, using the guide provided Easy installation Screw the lugs to the enclosure, twist 30 degrees and your bracket is attached P L AST I C E N C LOS U R E S 4 x static mount points/slots Provides easy and flexible wall mount fitting C I R C U L A R WA L L M O U N T B R A C K E T GREY (GY) B L AC K ( B K ) WHITE (WH) CBWMC-GY CBWMC-BK CBWMC-WH INCLUDED 1 x circular wall mount bracket, 3 x screws, 3 x lugs R A N G E S P E C I F I C AT I O N MATERIAL DIAMETER PURCHASING INFORMATION Wall mount bracket UL94-V0 ABS Wall mount lugs UL94-V0 ABS Screws BZP (Bright Zinc Plated Steel) 98.3 mm Country of origin Great Britain (GB) Commodity code 3923101000 Weight 23.6g +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 Vers 1 378
CBHEX1-PI4-BK
1. 物料型号:文档中没有明确列出物料型号,但提到了产品名称为Hex-Box IoT Enclosure。
2. 器件简介:Hex-Box IoT Enclosure是在英国制造的,设计注重定制和用户灵活性。外壳100%可回收,具有六个自锁面板,可根据需求混合搭配。外壳适用于工业物联网环境,具有巨大的连接器访问和空气流通优势。
3. 引脚分配:文档中没有提供具体的引脚分配信息。
4. 参数特性: - 材料:UL94-VO ABS - 颜色:灰色(RAL7047)、黑色(RAL9005)、白色(RAL9003) - 符合性:RoHS合规 - 工作温度:-10°C至+80°C - 螺丝扭矩:0.3Nm
5. 功能详解: - 顶部和底部都可安装PCB。 - 顶部有六个安装点,底部有四个,带有适配Raspberry Pi的安装足迹。 - 底部有编号索引。 - 有助于壁挂安装和自定义。 - 允许从所有侧面进行电缆进入。
6. 应用信息:适用于工业物联网、智能家居、智能办公室、零售、扬声器/报警器、会议室设备、网络设备、环境传感器设备、开发板电子等。
7. 封装信息: - 外部尺寸:146x130x45mm - 内部尺寸:122.5x125x34.5mm - 壁厚:25mm
CBHEX1-PI4-BK 价格&库存
很抱歉,暂时无法提供与“CBHEX1-PI4-BK”相匹配的价格&库存,您可以联系我们找货
