CDICMP004
CDICMP004
    CAMDENBOSS
CDICMP004 数据手册
M E TA L E N C L O S U R E S 408 METAL ENCLOSURES 110 Series Aluminium Instrumentation Enclosure Product overview 423 UNIVERSAL METAL ENCLOSURES CDIC Extensive range of high quality instrument cases for test, measurement, display and control applications. Functional push-fit construction designed for quick and easy assembly. • • • • Screwless push-fit assembly via 8x lock pins Horizontal PCB guides in side profiles Ventilation slots in lid and base Lid and base can be dismounted independently from each other • 4x non-slip feet as standard (CDIC00001-4) • 2x non-slip feet, 2x tilting feet and front handles as standard (CDIC00005-7) S P E C I F I C AT I O N Material High impact ABS Lid and base 1mm thick steel, epoxy coated, textured Side profiles extruded 6063 aluminium, matt silver anodised Brackets and tilting feet Material sizes 1-4 CDIC00001-4 Front/rear panels 1.5mm thick 5050 aluminium, silver anodised Material sizes 5-7 CDIC00005-7 Front/rear panels 2mm thick 5050 aluminium, silver anodised Standard unit sizes 1-4 CDIC00001-4 Lid and base 2x front/rear panels 2x aluminium side profiles 4x brackets 8x lock pins 4x non-slip feet Standard unit sizes 5-7 CDIC00005-7 Lid and base 2x front/rear panels 2x aluminium side profiles 2x rear brackets 2x front brackets with handle 2x non-slip feet 2x non-slip tilting feet 8 x locking pins DARK GREY SIZE LENGTH WIDTH HEIGHT CDIC00001 1 145mm 171.6mm 70.4mm CDIC00002 2 205mm 221.6mm 70.4mm CDIC00003 3 175mm 246.6mm 80.4mm CDIC00004 4 205mm 271.6mm 90.4mm CDIC00005 5 271mm 327.5mm 100mm CDIC00006 6 311mm 377.5mm 120mm CDIC00007 7 351mm 427.5mm 130mm K E Y F E AT U R E S Push-fit assembly | High-impact ABS | Extruded side profiles Assembly plate DA R K G R E Y SIZE LENGTH W I DT H • The assembly plate is easily fixed to the enclosure using M3 screws and nuts - 1 - - CDICMP002 2 143mm 192mm • 1 mm thick steel, zinc coated CDICMP003 3 113mm 217mm • Assembly plate for mounting components CDICMP004 4 143mm 242mm CDICMP005 5 170mm 286.5mm CDICMP006 6 210mm 336.5mm CDICMP007 7 250mm 386.5mm M E TA L E N C L O S U R E S ACC E SS O R I E S +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 Vers31 Vers 419
CDICMP004 价格&库存
很抱歉,暂时无法提供与“CDICMP004”相匹配的价格&库存,您可以联系我们找货
