D I N R A I L E N C LOS U R E S
DIN Rail modular enclosures
Product overview
CNMB
• Designed to meet the requirements of DIN 43880
• Snap fit modular design for ease of assembly and custom
kitting
• Base fits 35mm (EN60715) DIN Rail or directly to flat surface
• Moulded in light grey UL94-V0 flame retardant polycarbonate
• Carries up to 3 PCBs horizontally or 2 vertically
• Base PCB screw size - No.6 x 1/4” self tapping screw
• Snap fit terminal cover options for IP20 finger protection
• Snap in top covers available in grey, clear, transparent red and
smoked
• Standard enclosure consists of base, top and rail/wall clips
• Open top as standard, solid top, vented and extended wall
options available
• Covers and terminal guards ordered separately and can be
supplied in kits
• Easily customised covers and terminal guards and CNMB base
• Clear, smoked and red covers are moulded in PC UL94-V2
• Grey covers are PC UL94-V0
• Enclosed base offers isolation from DIN Rail
• Front panel (covers) ideal for screen printing and recessed solid
top for labels and membranes
• Other colours and EMC shielding available to order
B OX L E N G T H
A
H O R I Z O N TA L P C B S I Z E S
B
C
VERTICAL PCB SIZES
E
D
CNMB/1-
17.5mm
86.5x14mm
57x14mm
41.8x14mm
34x59.6mm
40x14.8mm
CNMB/2-
36mm
86.5x33mm
57x32mm
42x32mm
34x59.6mm
40x33mm
CNMB/3-
53.4mm
86.5x50mm
57x49mm
42x49mm
34x59.6mm
40x50mm
CNMB/4-
71.2mm
86.5x68mm
57x67mm
42x67mm
34x59.6mm
40x68mm
CNMB/5-
88mm
86.5x84mm
57x83mm
42x83mm
34x59.6mm
40x84mm
CNMB/6-
106.2mm
86.5x103mm
57x102mm
42x102mm
34x59.6mm
40x103mm
CNMB/9-
159.2mm
86.5x156mm
57x155.5mm
42x155mm
34x59.6mm
40x155mm
CNMB/12-
212.1mm
86.5x208mm
57x207mm
42x207mm
34x59.6mm
40x208mm
For exposed terminal positions both sides, add /2 to part number (e.g. CNMB/5/2)
For exposed terminal positions one side only, add /1 to part number (e.g. CNMB/5/1). Please note, this is only available as standard in sizes 5, 6 and 9
Box supplied with open top as standard
For solid recessed top used for membrane keypads or clear covers to enclose labels, add ST to part number (e.g. CNMB/3ST/2)
For cooling vents both sides add V to part number (e.g. CNMB/3V/2)
For extended side walls which meet the lower PCB behind terminals, add W to part number (e.g. CNMB/3W/2) - terminal guards do not fit extended wall versions
Combinations of body types are available (e.g. solid top with vented sides). These may be subject to MOQ
Vented sides
(V)
Extended walls
(W)
Vertical PCB
positions
Horizontal PCB sizes
Solid top
(ST)
Horizontal PCB
positions
D
E
B
C
A
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers
Vers4 1
393
Double row terminals/covers both sides
y
y
y
X
71.2
y
9/2
y
6/2
y
X
53.4
X
21.3
88.0
X
113.8
X
60.6
5/2
y
X
36.0
X
42.6
4/2
y
y
3/2
y
X
X
y
y
y
90.0
(pitch of wall mounting
holes in DIN Rail clips)
98 (1/2 to 4/2)
2/2
1/2
X
17.5
X
y
X
X
X
30.2
106.2
56.9
159.2
Single row terminals/covers on one side
X
X
X
y
9/1
y
X
212.1
99.8
99.8
y
113.8
6/1
y
X MINAL GUARDS
TER
93
holes in din rail clips)
y
12/2
99.8 (5/2 to 12/2)
y
60.6
30.2
106.0
X
167
56.9
159.0
Solid
D
E
CNMB/1/TGS
Solid
17.5mm
15.0mm
14.3mm
CNMB/2/TGS
Solid
35.5mm
29.9mm
13.8mm
CNMB/3/TGS
Solid
52.8mm
45.5mm
13.8mm
CNMB/4/TGS
Solid
70.6mm
59.9mm
13.8mm
CNMB/5/TGS
Solid
87.6mm
79.5mm
13.8mm
CNMB/x/TGS
A
20.0
A
E
D
20.0
STYLE
8
PA R T N O .
0.8
1.5
For 6, 9 and 12 size module use CNMB/3TGS
5.08mm pitch perforated
CNMB/x/TG508P
STYLE
A
D
E
CNMB/1/TG508P
Perforated
17.5mm
15.0mm
14.3mm
CNMB/2/TG508P
Perforated
35.5mm
29.9mm
13.8mm
CNMB/3/TG508P
Perforated
52.8mm
45.5mm
13.8mm
CNMB/4/TG508P
Perforated
70.6mm
59.9mm
13.8mm
CNMB/5/TG508P
Perforated
87.6mm
79.5mm
13.8mm
A
E
D
8
PA R T N O .
0.8
1.5
For 6, 9 and 12 size module use CNMB/3/TG508P
394
A
B
C
D
E
3
17.5mm
2.3mm
2.3mm
15.0mm
14.3mm
CNMB/2/TG508
Pre-drilled
6
35.5mm
0.9mm
2.7mm
29.9mm
13.8mm
CNMB/3/TG508
Pre-drilled
9
52.8mm
2.3mm
2.3mm
45.5mm
13.8mm
CNMB/4/TG508
Pre-drilled
12
70.6mm
2.7mm
5.8mm
59.9mm
13.8mm
CNMB/5/TG508
Pre-drilled
15
87.6mm
2.7mm
5.8mm
79.5mm
13.8mm
A
CNMB/x/TG508
B
7.3
POLES
Pre-drilled
C
E
D
20.0
STYLE
CNMB/1/TG508
8
PA R T N O .
0.8
1.5
STYLE
POLES
A
B
C
D
E
Pre-drilled
2
17.5mm
2.3mm
2.3mm
15.0mm
14.3mm
CNMB/2/TG750
Pre-drilled
4
35.5mm
0.9mm
2.7mm
29.9mm
13.8mm
CNMB/3/TG750
Pre-drilled
6
52.8mm
2.3mm
2.3mm
45.5mm
13.8mm
CNMB/4/TG750
Pre-drilled
8
70.6mm
2.7mm
5.8mm
59.9mm
13.8mm
CNMB/5/TG750
Pre-drilled
10
87.6mm
2.7mm
5.8mm
79.5mm
13.8mm
For 6, 9 and 12 size module use CNMB/3/TG750
Vers
Vers 2
1
A
CNMB/x/TG750
B
C
E
D
20.0
PA R T N O .
CNMB/1/TG750
7.3
7. 5 m m p i t c h p r e - d r i l l e d
8
5.08mm pitch pre-drilled
0.8
1.6
1 0.1 6 m m p i tc h p re - d r i l l e d
POLES
A
B
C
D
E
Pre-drilled
2
17.5mm
1.0mm
1.0mm
15.0mm
14.3mm
CNMB/2/TG100
Pre-drilled
3
35.5mm
0.9mm
0.9mm
29.9mm
13.8mm
CNMB/3/TG100
Pre-drilled
5
52.8mm
1.0mm
1.0mm
45.5mm
13.8mm
CNMB/4/TG100
Pre-drilled
6
70.6mm
2.7mm
2.7mm
59.9mm
13.8mm
CNMB/5/TG100
Pre-drilled
7
87.6mm
2.7mm
5.8mm
79.5mm
13.8mm
C
B
E
D
8
20.0
STYLE
CNMB/1/TG100
7.3
A
CNMB/x/TG100
PA R T N O .
0.8
1.5
For 6, 9 and 12 size module use CNMB/3/TG100
RJ45 5.08mm pitch perforated
CNMB/x/TGRJ45
PA R T N O .
STYLE
POLES
A
B
C
D
E
CNMB/3/TGRJ45
Perforated
5
52.8mm
1.0mm
1.0mm
45.5mm
13.8mm
A
12.50
19.80
B
Can be used on sizes 3, 6, 9 and 12
C
D
E
1
5
19.80
1.50
MINI USB 5.08mm pitch perforated
CNMB/x/TGMINIUSB
PA R T N O .
STYLE
POLES
A
B
C
D
E
CNMB/3/TGMINIUSB
Perforated
7
52.8mm
1.0mm
1.0mm
45.5mm
13.8mm
A
C 12.50
B
19.80
E
D
5
19.80 1
1.50
USB 5.08 pitch perforated
CNMB/x/TGUSB
PA R T N O .
STYLE
POLES
A
B
C
D
E
CNMB/3/TGUSB
Perforated
6
52.8mm
1.0mm
1.0mm
45.5mm
13.8mm
A
19.80
B
8
D
5
C
E
1
1.50
COV E R S
Standard covers
S M O K E D T R A N S PA R E N T
C L E A R T R A N S PA R E N T
GREY
SIZE
CNMB/1/PR
CNMB/1/PS
CNMB/1/PC
CNMB/1/PG
1
CNMB/2/PR
CNMB/2/PS
CNMB/2/PC
CNMB/2/PG
2
CNMB/3/PR
CNMB/3/PS
CNMB/3/PC
CNMB/3/PG
3
CNMB/4/PR
CNMB/4/PS
CNMB/4/PC
CNMB/4/PG
4
CNMB/5/PR
CNMB/5/PS
CNMB/5/PC
CNMB/5/PG
5
CNMB/6/PR
CNMB/6/PS
CNMB/6/PC
CNMB/6/PG
6
CNMB/9/PR
CNMB/9/PS
CNMB/9/PC
CNMB/9/PG
9
CNMB/12/PC
CNMB/12/PG
12
R E D T R A N S PA R E N T
Vers
Vers21
395
Curved covers
GREY
SIZE
CNMB/2/PRC
CNMB/2/PSC
CNMB/2/PCC
CNMB/2/PGC
2
CNMB/3/PRC
CNMB/3/PSC
CNMB/3/PCC
CNMB/3/PGC
3
CNMB/4/PRC
CNMB/4/PSC
CNMB/4/PCC
CNMB/4/PGC
4
CNMB/5/PRC
CNMB/5/PSC
CNMB/5/PCC
CNMB/5/PGC
5
CNMB/6/PRC
CNMB/6/PSC
CNMB/6/PCC
CNMB/6/PGC
6
CNMB/9/PRC
CNMB/9/PSC
CNMB/9/PCC
CNMB/9/PGC
9
EXTENDED HEIGHT MODULES
• 16mm high
CNMB/x/E
• Accepts curved hinged cover only
PA R T N O .
W I DT H
SIZE
CNMB/2/E
34.7mm
2
• Adds an additional horizontal PCB slot
CNMB/3/E
52.0mm
3
• Does not fit on solid top CNMB’s
CNMB/4/E
70.0mm
4
CNMB/5/E
86.5mm
5
CNMB/6/E
104.5mm
6
CNMB/9/E
157.7mm
9
Curved hinged covers
GREY
SIZE
CNMB/2/HPRC
CNMB/2/HPCC
CNMB/2/HPGC
2
CNMB/3/HPRC
CNMB/3/HPCC
CNMB/3/HPGC
3
CNMB/4/HPRC
CNMB/4/HPCC
CNMB/4/HPGC
4
CNMB/5/HPRC
CNMB/5/HPCC
CNMB/5/HPGC
5
CNMB/6/HPRC
CNMB/6/HPCC
CNMB/6/HPGC
6
CNMB/9/HPRC
CNMB/9/HPCC
CNMB/9/HPGC
9
For use with extended height module only
E N C LOS U R E K I TS
CNMB/x/KIT
KIT
STANDARD
396
• Each kit contains one grey panel cover and a selection
of solid and perforated terminal guards
KIT
• Kits of the most frequently used components are
available to order
* For size 6, 9 and 12, multiple ‘size 3’ terminal guards are supplied. For
example size 6 requires 2x ‘size 3’ guards per side.
EXTENDED HEIGHT
Kits are also available for vented, solid top and extended wall bodies e.g.
CNMB/2ST/KIT.
Extended wall kits do not come with terminal guards
Vers 2
1
TERMINAL
GUARDS
EXTENSION
MODULE
COMPONENT
COV E R
KIT PART NO.
/PG
/TG508P
/TGS
CNMB/1/KIT
1
2
1
CNMB/2/KIT
1
2
1
/E
CNMB/3/KIT
1
2
1
CNMB/4/KIT
1
2
1
CNMB/5/KIT
1
2
1
CNMB/6/KIT
1
4*
2*
CNMB/9/KIT
1
6*
3*
CNMB/12/KIT
1
8*
4*
COMPONENT
COV E R
TERMINAL
GUARDS
EXTENSION
MODULE
KIT PART NO.
/HPCC
/TG508P
/TGS
/E
CNMB/2E/KIT
1
2
1
1
CNMB/3E/KIT
1
2
1
1
CNMB/4E/KIT
1
2
1
1
CNMB/5E/KIT
1
2
1
1
CNMB/6E/KIT
1
4*
2*
1
CNMB/9E/KIT
1
6*
3*
1
CNMB/2
CNMB/3
C N M B /6 *
CNMB/9*
CNMB/12*
4
8
12
16
12
12
CTBP0305
PCB terminal
Rising clamp
4
8
12
16
12
12
CTBP92VD/R
Pluggable terminal female
Rising clamp
4
8
12
16
12
12
CTBP93VD
Pluggable terminal male
4
8
12
16
12
12
CTBP0308
PCB terminal
Rising clamp
4
8
12
16
12
12
CTBP92VE/R
Pluggable terminal
Rising clamp
4
8
12
16
12
12
CTBP93VE
4
8
12
16
12
12
CTBP5000
PCB terminal
Wire protector
3
6
9
12
15
9
9
9
CTBP0500
PCB terminal
Rising clamp
3
6
9
12
15
9
9
9
CTBP1000
PCB terminal
Wire protector
3
6
9
12
15
9
9
9
CTBP0100
PCB terminal
Rising clamp
3
6
9
12
15
9
9
9
CTB7000
PCB terminal
Rising clamp
3
6
9
12
15
9
9
9
CTBP92VG/R
Rising clamp
3
6
9
12
15
9
9
9
CTBP9300
3
6
9
12
15
9
9
9
CTBP0108
PCB terminal
Rising clamp
3
6
9
12
15
9
9
9
CTBP0508
PCB terminal
Rising clamp
3
6
9
12
15
9
9
9
CTBP0708
PCB terminal
Rising clamp
3
6
9
12
15
9
9
9
CTBP92VJ/R
Rising clamp
3
6
9
12
15
9
9
9
CTBP9308
3
6
9
12
15
9
9
9
CTBP55VK
PCB terminal
Wire protector
2
4
6
8
10
6
6
6
CTBP07VK
PCB terminal
Rising clamp
2
4
6
8
10
6
6
6
CTBP0110
PCB terminal
Rising clamp
2
4
6
8
10
6
6
6
9.5MM
CTBP04VZ
PCB terminal
Rising clamp
5
6
8
5
5
5
CTB0609
PCB terminal
Rising clamp
5
7
9
5
5
5
T E R M I N A L B LO C K
PA R T N U M B E R
C N M B /4
PITCH
CNMB/5
CNMB/1
CTBP3051
PCB terminal
Wire protector
1 0.1 6 M M
C N M B T E R M I N A L B LO C K S E L E C T I O N
CHART
7. 5 M M
5.08MM
5MM
3.81MM
3.5MM
NUMBER OF POLES
Please note: size /6, /9 & /12 have the same sized terminal space as a size /3 housing
and therefore use the same sized terminal blocks
Vers 1
397
很抱歉,暂时无法提供与“CNMB/4V/KIT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+130.370401+16.93446
- 10+118.0929010+15.33967
- 25+113.5192125+14.74557
- 50+110.1791550+14.31172
- 100+106.93616100+13.89047
- 250+102.79345250+13.35235
- 500+99.76605500+12.95911
