SCREWLESS
PLUGGABLES
S TA N D A R D
P C B T E R M I N A L B LO C KS
002
PCB TERMINAL
BLOCKS
2.54mm screwless terminal blocks
081
TERMINAL STRIPS
Product overview
S P E C I F I C AT I O N
Interlocking modules
Easily breakable to desired number of poles
Guided pin alignment
Choice of vertical or horizontal cable entry
Moulded in green UL94-V0 PA66
0.08-1.3mm2 cable (28-16AWG)
US approved
C
Rating
10A/300V
Insulation withstand voltage
AC1250V/1 min
Insulation resistance
500MΩ at DC500V
Operating temperature
-40°C to +115°C
Moulding
UL94-V0 PA66
Pin/contact
Tin plated brass
Recommended PCB hole size
1.1mm
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
5
15.2mm
CSTBP254V/6
6
17.8mm
CSTBP254V/7
7
20.3mm
CSTBP254V/8
8
22.9mm
CSTBP254V/9
9
25.4mm
CSTBP254V/10
10
27.9mm
CSTBP254V/11
11
30.5mm
CSTBP254V/12
12
33.0mm
PA R T N O .
POLES
LENGTH
CSTBP254H/2
2
7.6mm
CSTBP254H/3
3
10.2mm
CSTBP254H/4
4
12.7mm
CSTBP254H/5
5
15.2mm
CSTBP254H/6
6
17.8mm
CSTBP254H/7
7
20.3mm
CSTBP254H/8
8
1.05
2.54
9
25.4mm
CSTBP254H/10
10
27.9mm
CSTBP254H/11
11
30.5mm
CSTBP254H/12
12
33.0mm
158
INTERFACE
MODULES AND
RELAY BASES
2.54
0.80
0.50
0.50
5.08
PCB LAYOUT
2.54x(N-1)
2.90
CSTBP254H
22.9mm
CSTBP254H/9
12.60
2.54x(N+1)
13.60
1.05
13.60
CSTBP254V/5
2.54x(N+1)
12.60
12.7mm
13.60
4
3.50
10.2mm
CSTBP254V/4
12.60
7.6mm
3
3.50
2
CSTBP254V/3
.20
CSTBP254V/2
IP68 CONNECTORS
CSTBP254V
Ø1
LENGTH
.20
POLES
Ø1
PA R T N O .
2.54
0.50
0.80
2.54
2.54x(N-1)
5.08
2.54x(N-1)
K E Y F E AT U R E S
| Modular design
CONNECT
Dual row pins | Space saving pitch size
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
85
很抱歉,暂时无法提供与“CSTBP254H/3”相匹配的价格&库存,您可以联系我们找货
