CTB0118/2
CTB0118/2
    CAMDENBOSS
CTB0118/2 数据手册
PCB TERMINAL BLOCKS PCB TERMINAL BLOCKS INTERCONNECTION FUSES & FUSEHOLDERS LEDs & INDICATORS MINIATURE SWITCHES LIMIT & SAFETY SWITCHES 7.62mm Pitch Standard Profile Rising Clamp Terminal Blocks •  2 & 3 pole double interlocking mechanism for increased strength • 4-12 pole pre-assembled • Moulded in green UL94-V0 flame retardant PA66 • Professional rising clamp terminals • 0.2-4.0mm2 (30-12AWG) solid cable • 0.2-2.5mm2 (30-12AWG) stranded cable • Guided pin alignment • , , approved SPECIFICATION Rating CTB0118 Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size TYPE NO. CTB0118/2 CTB0118/3 CTB0118/4 CTB0118/5 CTB0118/6 CTB0118/7 CTB0118/8 CTB0118/9 CTB0118/10 CTB0118/11 CTB0118/12 POLES 2 3 4 5 6 7 8 9 10 11 12 24A/500V UL=14A/300V, VDE&IMQ=24A/750V ≥3kV 6kV 110°C UL94-V0 flame retardant PA66 Tinned, nickel plated brass Tinned, nickel plated brass M3 steel zinc plated, 0.5Nm ø1.5mm LENGTH 15.2mm 22.9mm 30.5mm 38.1mm 45.7mm 53.3mm 61mm 68.6mm 76.2mm 83.8mm 91.4mm CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES BATTERIES SOLAR PANELS TRANSFORMERS We operate a constant improvement policy, our products are subject to change without notice. Ver 1.1 +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com
CTB0118/2 价格&库存
很抱歉,暂时无法提供与“CTB0118/2”相匹配的价格&库存,您可以联系我们找货
