CTB0355/8
CTB0355/8
    CAMDENBOSS
CTB0355/8 数据手册
PCB TERMINAL BLOCKS PCB TERMINAL BLOCKS 3.5mm Pitch Ultra Low Profile 90˚ Rising Clamp Terminal • • • • 2-12 pole interlocking 4-12 pole pre-assembled Ultra low profile Moulded in green UL94-V0 flame retardant PA • Professional rising clamp terminals • 0.2-1.5mm2 (30-16AWG) solid cable • 0.2-1.0mm2 (30-16AWG) stranded cable • Captive screws • Guided pin alignment • Double interlock mechanism for increased strength • , , approved SPECIFICATION Rating CTB0355 Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size TYPE NO. CTB0355/2 CTB0355/3 CTB0355/4 CTB0355/5 CTB0355/6 CTB0355/7 CTB0355/8 CTB0355/9 CTB0355/10 CTB0355/11 CTB0355/12 POLES 2 3 4 5 6 7 8 9 10 11 12 10A/160V UL=10A/300V, VDE&IMQ=10A/130V 1.25kV 2.5kV 110°C UL94-V0 flame retardant PA66 Tinned, nickel plated brass Tinned, nickel plated brass M2 steel zinc plated, 0.3Nm ø1.1mm INTERCONNECTION FUSES & FUSEHOLDERS LEDs & INDICATORS MINIATURE SWITCHES LENGTH 7mm 10.5mm 14mm 17.5mm 21mm 24.5mm 28mm 31.5mm 35mm 38.5mm 42mm LIMIT & SAFETY SWITCHES CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES BATTERIES SOLAR PANELS TRANSFORMERS +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Ver 1.1
CTB0355/8 价格&库存
很抱歉,暂时无法提供与“CTB0355/8”相匹配的价格&库存,您可以联系我们找货
