CTB5202/5
CTB5202/5
    CAMDENBOSS
CTB5202/5 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS ECONOMY RANGE 5mm pitch low profile terminal blocks Product overview CTB5202 • 2-12 pole interlocking • Moulded in black UL94-V0 flame retardant PA66 • Wire protector terminals • Guided pin alignment • 0.3-2 mm2 (22-14 AWG) • approved LENGTH 2 10mm Insulation resistance 5000M Ω/1000V CTB5202/3 3 15mm Withstand voltage AC1500V/1min CTB5202/4 4 20mm Contact resistance 20mΩ (max) CTB5202/5 5 25mm Working temperature -33°C to 120+°C CTB5202/6 6 30mm Mouldings UL94-V0 flame retardant PA66 CTB5202/7 7 35mm Pin/terminal Nickel plated brass CTB5202/8 8 40mm Wire protector Stainless steel CTB5202/9 9 45mm CTB5202/10 10 50mm CTB5202/11 11 55mm CTB5202/12 12 60mm Screw/torque Recommended PCB hole size M2.5 steel, nickel plated 0.4Nm ø1.3mm 1.1 7.6 POLES CTB5202/2 0.6 5xP 0.6 5xP 3.5 10 PA R T N O . 16A 250V 3.5 S P E C I F I C AT I O N Rating 2.5 1 5 K E Y F E AT U R E S E CO N O M Y R A N G E P C B T E R M I N A L B LO C KS U L 9 4 -V 0 PA 6 6 m o u l d i n g | 1 2 0 ° C m a x i m u m w o r k i n g t e m p e r a t u r e | I n t e r l o c k i n g 1 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 EMS 613558
CTB5202/5 价格&库存
很抱歉,暂时无法提供与“CTB5202/5”相匹配的价格&库存,您可以联系我们找货
