CTB5000/4
CTB5000/4
    CAMDENBOSS
CTB5000/4 数据手册
PCB TERMINAL BLOCKS 5mm Pitch Low Profile Screw Terminal Blocks • 2 & 3 pole interlocking • 4-12 pole solid block end stackable • Test probe facility • Moulded in grey UL94-V0 flame retardant PC • Wire protector terminals • 0.5-1.5mm2 (30-14AWG) solid cable • 0.5-1.0mm2 (30-14AWG) stranded cable • Guided pin alignment • Anti solder wicking terminal • , , approved PCB TERMINAL BLOCKS SPECIFICATION Rating CTB5000 Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Wire protector Screw/torque Recommended PCB hole size 13.5A/250V UL=14A/300V, VDE&IMQ=13.5A/250V ≥2kV 4kV 85°C UL94-V0 flame retardant PC Tinned, nickel plated brass Tin plated phosphor bronze M2.5 steel zinc plated, 0.4Nm ø1.1mm INTERCONNECTION FUSES & FUSEHOLDERS LEDs & INDICATORS TYPE NO. CTB5000/2 CTB5000/3 CTB5000/4 CTB5000/5 CTB5000/6 CTB5000/7 CTB5000/8 CTB5000/9 CTB5000/10 CTB5000/11 CTB5000/12 POLES 2 3 4 5 6 7 8 9 10 11 12 LENGTH 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm MINIATURE SWITCHES LIMIT & SAFETY SWITCHES CONTROL PRODUCTS 5mm Pitch Low Profile 90˚ Screw Terminal Blocks • • • • • • • • • • • 2 & 3 pole interlocking 4-12 pole solid block Test probe facility 90° Mounting Moulded in grey UL94-V0 flame retardant PC Wire protector terminals 0.5-1.5mm2 (30-14AWG) solid cable 0.5-1.0mm2 (30-14AWG) stranded cable Anti solder wicking terminal Guided pin alignment , , approved INTERFACE MODULES & SUPPORTS SPECIFICATION Rating CTB5050 Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Wire protector Screw/torque Recommended PCB hole size 13.5A/250V UL=14A/300V, VDE&IMQ=13.5A/250V ≥2kV 4kV 85°C UL94-V0 flame retardant PC Tinned, nickel plated brass Tin plated phosphor bronze M2.5 steel zinc plated, 0.4Nm ø1.1mm RELAY BASES DIN RAIL ENCLOSURES BATTERIES TYPE NO. CTB5050/2 CTB5050/3 CTB5050/4 CTB5050/5 CTB5050/6 CTB5050/7 CTB5050/8 CTB5050/9 CTB5050/10 CTB5050/11 CTB5050/12 POLES 2 3 4 5 6 7 8 9 10 11 12 +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com LENGTH 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm SOLAR PANELS TRANSFORMERS We operate a constant improvement policy, our products are subject to change without notice. Ver 1.1
CTB5000/4 价格&库存
很抱歉,暂时无法提供与“CTB5000/4”相匹配的价格&库存,您可以联系我们找货
