CTB9200/4A
CTB9200/4A
    CAMDENBOSS
CTB9200/4A 数据手册
PCB TERMINAL BLOCKS PCB TERMINAL BLOCKS INTERCONNECTION FUSES & FUSEHOLDERS 5mm Pitch Pluggable Rising Clamp Terminal Blocks • 2-24 pole solid block • Pluggable male-female connectors • Open & closed headers • Horizontal & vertical female plug styles • Polarised mouldings • Moulded in green UL94-V0 flame retardant PA • Professional rising clamp terminals • 0.2-2.5mm2 (30-12AWG) solid & stranded cable • Anti solder wicking • Captive screws • Guided pin alignment • , , approved SPECIFICATION Rating Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size 20A/320V UL=12A/300V, VDE&IMQ=20A/320V ≥2.5kV 4kV 100°C UL94-V0 flame retardant PA Copper alloy, NI & SN Copper alloy, NI & SN M3 steel zinc plated, 0.5Nm ø1.4mm LEDs & INDICATORS CTB9200 Female connector MINIATURE SWITCHES LIMIT & SAFETY SWITCHES CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES BATTERIES SOLAR PANELS TRANSFORMERS TYPE NO. CTB9200/2A CTB9200/3A CTB9200/4A CTB9200/5A CTB9200/6A CTB9200/7A CTB9200/8A CTB9200/9A CTB9200/10A CTB9200/11A CTB9200/12A CTB9200/13A POLES 2 3 4 5 6 7 8 9 10 11 12 13 LENGTH 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 65mm TYPE NO. CTB9200/14A CTB9200/15A CTB9200/16A CTB9200/17A CTB9200/18A CTB9200/19A CTB9200/20A CTB9200/21A CTB9200/22A CTB9200/23A CTB9200/24A POLES 14 15 16 17 18 19 20 21 22 23 24 LENGTH 70mm 75mm 80mm 85mm 90mm 95mm 100mm 105mm 110mm 115mm 120mm CTB92VG/S Female connector vertical (standard) TYPE NO. CTB92VG/2S CTB92VG/3S CTB92VG/4S CTB92VG/5S CTB92VG/6S CTB92VG/7S CTB92VG/8S CTB92VG/9S CTB92VG/10S CTB92VG/11S CTB92VG/12S CTB92VG/13S POLES 2 3 4 5 6 7 8 9 10 11 12 13 LENGTH 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 65mm TYPE NO. CTB92VG/14S CTB92VG/15S CTB92VG/16S CTB92VG/17S CTB92VG/18S CTB92VG/19S CTB92VG/20S CTB92VG/21S CTB92VG/22S CTB92VG/23S CTB92VG/24S POLES 14 15 16 17 18 19 20 21 22 23 24 LENGTH 70mm 75mm 80mm 85mm 90mm 95mm 100mm 105mm 110mm 115mm 120mm Female connector vertical (reversed) TYPE NO. CTB92VG/2R CTB92VG/3R CTB92VG/4R CTB92VG/5R CTB92VG/6R CTB92VG/7R CTB92VG/8R CTB92VG/9R CTB92VG/10R CTB92VG/11R CTB92VG/12R CTB92VG/13R POLES 2 3 4 5 6 7 8 9 10 11 12 13 LENGTH 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 65mm TYPE NO. CTB92VG/14R CTB92VG/15R CTB92VG/16R CTB92VG/17R CTB92VG/18R CTB92VG/19R CTB92VG/20R CTB92VG/21R CTB92VG/22R CTB92VG/23R CTB92VG/24R CTB92VG/R POLES 14 15 16 17 18 19 20 21 22 23 24 LENGTH 70mm 75mm 80mm 85mm 90mm 95mm 100mm 105mm 110mm 115mm 120mm We operate a constant improvement policy, our products are subject to change without notice. Ver 1.1 +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com
CTB9200/4A 价格&库存
很抱歉,暂时无法提供与“CTB9200/4A”相匹配的价格&库存,您可以联系我们找货
CTB9200/4A
  • 1+28.17938
  • 10+24.90464
  • 100+22.94691
  • 250+21.81974
  • 500+21.13157
  • 1000+19.77896
库存:1163
