PCB TERMINAL BLOCKS
PCB
TERMINAL
BLOCKS
INTERCONNECTION
FUSES &
FUSEHOLDERS
5mm Pitch Pluggable Rising Clamp Terminal Blocks
• 2-24 pole solid block
• Pluggable male-female
connectors
• Open & closed headers
• Horizontal & vertical
female plug styles
• Polarised mouldings
• Moulded in green UL94-V0
flame retardant PA
• Professional rising
clamp terminals
• 0.2-2.5mm2 (30-12AWG)
solid & stranded cable
• Anti solder wicking
• Captive screws
• Guided pin alignment
, , approved
SPECIFICATION
Rating
Dielectric strength
Impulse withstand voltage
Working temperature
Moulding
Pin/terminal
Rising clamp
Screw/torque
Recommended PCB hole size
20A/320V
UL=12A/300V, VDE&IMQ=20A/320V
≥2.5kV
4kV
100°C
UL94-V0 flame retardant PA
Copper alloy, NI & SN
M3 steel zinc plated, 0.5Nm
ø1.4mm
LEDs &
INDICATORS
CTB9200
Female connector
MINIATURE
SWITCHES
LIMIT &
SAFETY
SWITCHES
CONTROL
PRODUCTS
INTERFACE
MODULES &
SUPPORTS
RELAY
BASES
DIN RAIL
ENCLOSURES
BATTERIES
SOLAR
PANELS
TRANSFORMERS
TYPE NO.
CTB9200/2A
CTB9200/3A
CTB9200/4A
CTB9200/5A
CTB9200/6A
CTB9200/7A
CTB9200/8A
CTB9200/9A
CTB9200/10A
CTB9200/11A
CTB9200/12A
CTB9200/13A
POLES
2
3
4
5
6
7
8
9
10
11
12
13
LENGTH
10mm
15mm
20mm
25mm
30mm
35mm
40mm
45mm
50mm
55mm
60mm
65mm
TYPE NO.
CTB9200/14A
CTB9200/15A
CTB9200/16A
CTB9200/17A
CTB9200/18A
CTB9200/19A
CTB9200/20A
CTB9200/21A
CTB9200/22A
CTB9200/23A
CTB9200/24A
POLES
14
15
16
17
18
19
22
23
24
LENGTH
70mm
75mm
80mm
85mm
90mm
95mm
100mm
105mm
110mm
115mm
120mm
CTB92VG/S
Female connector vertical (standard)
TYPE NO.
CTB92VG/2S
CTB92VG/3S
CTB92VG/4S
CTB92VG/5S
CTB92VG/6S
CTB92VG/7S
CTB92VG/8S
CTB92VG/9S
CTB92VG/10S
CTB92VG/11S
CTB92VG/12S
CTB92VG/13S
POLES
2
3
4
5
6
7
8
9
10
11
12
13
LENGTH
10mm
15mm
20mm
25mm
30mm
35mm
40mm
45mm
50mm
55mm
60mm
65mm
TYPE NO.
CTB92VG/14S
CTB92VG/15S
CTB92VG/16S
CTB92VG/17S
CTB92VG/18S
CTB92VG/19S
CTB92VG/20S
CTB92VG/21S
CTB92VG/22S
CTB92VG/23S
CTB92VG/24S
POLES
14
15
16
17
18
19
22
23
24
LENGTH
70mm
75mm
80mm
85mm
90mm
95mm
100mm
105mm
110mm
115mm
120mm
Female connector vertical (reversed)
TYPE NO.
CTB92VG/2R
CTB92VG/3R
CTB92VG/4R
CTB92VG/5R
CTB92VG/6R
CTB92VG/7R
CTB92VG/8R
CTB92VG/9R
CTB92VG/10R
CTB92VG/11R
CTB92VG/12R
CTB92VG/13R
POLES
2
3
4
5
6
7
8
9
10
11
12
13
LENGTH
10mm
15mm
20mm
25mm
30mm
35mm
40mm
45mm
50mm
55mm
60mm
65mm
TYPE NO.
CTB92VG/14R
CTB92VG/15R
CTB92VG/16R
CTB92VG/17R
CTB92VG/18R
CTB92VG/19R
CTB92VG/20R
CTB92VG/21R
CTB92VG/22R
CTB92VG/23R
CTB92VG/24R
CTB92VG/R
POLES
14
15
16
17
18
19
22
23
24
LENGTH
70mm
75mm
80mm
85mm
90mm
95mm
100mm
105mm
110mm
115mm
120mm
We operate a constant improvement
policy, our products are subject to
change without notice.
Ver 1.1
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
很抱歉,暂时无法提供与“CTB9200/6A”相匹配的价格&库存,您可以联系我们找货
