PCB TERMINAL BLOCKS
5mm Pitch Pluggable for Vertical or 90˚ mounting Rising Clamp Terminal
• Unique 36 pole strip
• Easily cut to required
number of poles
• Can be supplied pre-cut to
specified number of poles
• Dual horizontal or
vertical mounting
• Moulded in grey UL94-V0
flame retardant PC
• Professional rising
clamp terminals
• 0.2-2.5mm2 (24-12AWG)
solid & stranded cable
• Optional polarising clips
• Anti solder wicking
• Guided pin alignment
• Captive screws
, ,approved
SPECIFICATION
Rating
Dielectric strength
Impule withstand voltage
Working temperature
Moulding
Pin/terminal
Rising clamp
Screw/torque
Recommended PCB hole size
16A/250V
UL=14A/300V, VDE&IMQ=16A/250V
≥2.5kV
4kV
130°C
UL94-V0 flame retardant PC
Tinned, nickel plated brass
Zinc plated steel
M2.5 steel zinc plated, 0.4Nm
ø1.3mm
PCB
TERMINAL
BLOCKS
INTERCONNECTION
FUSES &
FUSEHOLDERS
LEDs &
INDICATORS
Female connector
TYPE NO.
CTB7300/2F
CTB7300/3F
CTB7300/4F
CTB7300/5F
CTB7300/6F
CTB7300/7F
CTB7300/8F
CTB7300/9F
CTB7300/10F
CTB7300/11F
CTB7300/12F
CTB7300/36F
POLES
2
3
4
5
6
7
8
9
10
11
12
36
LENGTH
10mm
15mm
20mm
25mm
30mm
35mm
40mm
45mm
50mm
55mm
60mm
180mm
MINIATURE
SWITCHES
CTB7300/F
LIMIT &
SAFETY
SWITCHES
CONTROL
PRODUCTS
INTERFACE
MODULES &
SUPPORTS
PCB mounting male
TYPE NO.
CTB7300/2M
CTB7300/3M
CTB7300/4M
CTB7300/5M
CTB7300/6M
CTB7300/7M
CTB7300/8M
CTB7300/9M
CTB7300/10M
CTB7300/11M
CTB7300/12M
CTB7300/36M
POLES
2
3
4
5
6
7
8
9
10
11
12
36
LENGTH
10mm
15mm
20mm
25mm
30mm
35mm
40mm
45mm
50mm
55mm
60mm
180mm
CTB7300/M
RELAY
BASES
DIN RAIL
ENCLOSURES
BATTERIES
Polarising Clip
TYPE NO.
CTB7300C
1 pair
Fitted to each end of the male connector
ensures correct vertical or horizontal
orientation of the female part
CTB7300/C
SOLAR
PANELS
TRANSFORMERS
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
We operate a constant improvement
policy, our products are subject to
change without notice.
Ver 1.1
很抱歉,暂时无法提供与“CTB7300/36M”相匹配的价格&库存,您可以联系我们找货
