CTBP01HL/3
CTBP01HL/3
    CAMDENBOSS
    CAMDENBOSS - CTBP01HL/3 - Wire-To-Board Terminal Block, 7.62 mm, 3 Ways, 26 AWG, 12 AWG, 2.3 mm², Sc...
CTBP01HL/3 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 7. 6 2 m m s t a n d a r d p r o f i l e 9 0 ° r i s i n g clamp terminal blocks Product overview 081 TERMINAL STRIPS CTBP01HL • 2 and 3 pole double interlocking mechanism for increased strength • 4-12 pole pre-assembled • Moulded in green UL94-V0 flame retardant PA66 • Professional rising clamp terminals • Cable acceptance - 0.13-2.3mm2 (26-12AWG) • Guided pin alignment • C approved US , Moulding UL94-V0 flame retardant PA66 Pin/terminal Tinned, nickel plated brass Rising clamp Tinned, nickel plated brass Screw/torque M3 steel zinc plated, 0.5Nm Recommended PCB hole size ø1.6mm 15.24mm 3 22.86mm CTBP01HL/4 4 30.48mm CTBP01HL/5 5 38.10mm CTBP01HL/6 6 45.72mm CTBP01HL/7 7 53.34mm CTBP01HL/8 8 60.96mm CTBP01HL/9 9 68.58mm CTBP01HL/10 10 76.20mm CTBP01HL/11 11 83.82mm CTBP01HL/12 12 91.44mm 1.00 10.50 2 CTBP01HL/3 IP68 CONNECTORS 3.81 7.62 7.62(xx-1) 4.46 158 PCB layout 0.65 7.62xx A 0.65 INTERFACE MODULES AND RELAY BASES 18.00 -40°C to +105°C CTBP01HL/2 151 7.62(xx-1) 7.62 18.60 Working temperature LENGTH Ø1.60 1600V/1min POLES 0.80 UL=20A/300V, VDE=24A/450V Impulse withstand voltage PA R T N O . 17.50 Rating 100 CIRCULAR CONNECTORS 17.50 S P E C I F I C AT I O N 095 WIRE TO BOARD CONNECTORS 5.30±0.3 Section: A-A A K E Y F E AT U R E S | Professional rising clamp CONNECT Standard profile | Double interlock mechanism +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 43
CTBP01HL/3 价格&库存
很抱歉,暂时无法提供与“CTBP01HL/3”相匹配的价格&库存,您可以联系我们找货
