P C B T E R M I N A L B LO C KS
S TA N D A R D
SCREWLESS
PLUGGABLES
002
PCB TERMINAL
BLOCKS
081
TERMINAL STRIPS
3.81mm low profile vertical rising
clamp terminal blocks
Product overview
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
CTBP0308
2 and 3 pole Interlocking
4-12 pole solid block
Ultra low profile
Moulded in green UL94-V0 flame retardant PA
Professional rising clamp terminals
0.32-1.6mm2 (28-16AWG) cable
Captive screws
Guided pin alignment
Double interlock mechanism for increased
strength
• C
approved
US ,
IP68 CONNECTORS
Impulse withstand
voltage
2.0kV/1min
CTBP0308/3
3
11.4mm
CTBP0308/4
4
15.2mm
Working temperature
-40°C + 105°C
CTBP0308/5
5
19.1mm
Moulding
UL94-V0 flame retardant PA66
CTBP0308/6
6
22.9mm
Pin/terminal
Tinned, nickel plated brass
CTBP0308/7
7
26.7mm
CTBP0308/8
8
30.5mm
CTBP0308/9
9
34.3mm
CTBP0308/10
10
38.1mm
CTBP0308/11
11
41.9mm
CTBP0308/12
12
45.7mm
Rising clamp
Screw/torque
Recommended PCB
hole size
M2 steel zinc plated, 0.2Nm
ø1.3mm
1.91 3.81(xx-1)
3.81
7.40
7.62mm
PCB layout
3.81xx
A
0.35
8.50
UL=15A/300V, VDE=15A/250V
3.75
LENGTH
2
7.40
POLES
CTBP0308/2
3.75±0.3
0.50
3.50±0.3
INTERFACE
MODULES AND
RELAY BASES
PA R T N O .
Rating
Ø1.3
158
S P E C I F I C AT I O N
Section: A-A
K E Y F E AT U R E S
CONNECT
Ultra low profile | Double interlock mechanism
16
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
0.90
1.91
3.81
3.81(xx-1)
A
很抱歉,暂时无法提供与“CTBP0308/2”相匹配的价格&库存,您可以联系我们找货
