CTBP3051/2
CTBP3051/2
    CAMDENBOSS
    Conn Terminal Block F 2 POS 3.5mm Solder ST Thru-Hole 10A
CTBP3051/2 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 3.5mm pitch low profile commercial screw terminal blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 2 7mm CTBP3051/3 3 10.5mm Withstand voltage AC2000V/1min CTBP3051/4 4 14mm Contact resistance 20mΩ (max) CTBP3051/5 5 17.5mm Working temperature -40°C to +105°C CTBP3051/6 6 21mm Moulding UL94-V0 flame retardant PA66 CTBP3051/7 7 24.5mm Pin/terminal Tin plated brass CTBP3051/8 8 28mm Wire protector Phosphor bronze, nickel plated CTBP3051/9 9 31.5mm CTBP3051/10 10 35mm CTBP3051/11 11 38.5mm CTBP3051/12 12 42mm Recommended PCB hole size M2 steel, zinc plated 0.2Nm ø1.1mm 2 158 INTERFACE MODULES AND RELAY BASES 0.8 3.4 3.4 CTBP3051/2 500M Ω/500V 6.8 UL= 10A/300V, VDE =10A/250V Insulation resistance 151 IP68 CONNECTORS 8.4 LENGTH 3.5 POLES 6.8 PA R T N O . Rating Screw/torque 081 TERMINAL STRIPS CTBP3051 • 2-12 pole double interlock mechanism for increased strength • Wire protector terminals • Ultra low profile • UL94-V0 flame retardant PA66 • Cable acceptance - 0.5-1.0mm2 (24-18AWG) US , • C approved S P E C I F I C AT I O N PCB TERMINAL BLOCKS 2.3 2.3 K E Y F E AT U R E S | F l a m e r e t a r d a n t PA 6 6 CONNECT Wire protector terminals | Double interlock mechanism +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 13
CTBP3051/2 价格&库存
很抱歉,暂时无法提供与“CTBP3051/2”相匹配的价格&库存,您可以联系我们找货
