P C B T E R M I N A L B LO C KS
S TA N D A R D
PLUGGABLES
SCREWLESS
002
TERMINAL STRIPS
Product overview
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
IP68 CONNECTORS
• 2 and 3 pole double interlocking
mechanism for increased strength
• Professional rising clamp terminals
• Standard profile 90° mounting
• Moulded in green UL94-V0 flame
retardant PA66
• Cable acceptance - 0.6-2mm2 (22-12AWG)
• Guided pin alignment
• C
approved
US ,
S P E C I F I C AT I O N
PA R T N O .
POLES
LENGTH
UL=16A/250V, VDE=24A/250V
CTBP0115/2
2
15mm
Insulation resistance
500MΩ/500V
CTBP0115/3
3
22.5mm
Withstand voltage
AC2000V/1min
CTBP0115/4
4
30mm
Contact resistance
20mΩ (max)
CTBP0115/5
5
37.5mm
Working temperature
-40°C to +105°C
CTBP0115/6
6
45mm
CTBP0115/7
7
52.5mm
CTBP0115/8
8
60mm
CTBP0115/9
9
67.5mm
CTBP0115/10
10
75mm
CTBP0115/11
11
82.5mm
CTBP0115/12
12
90mm
Rating
158
INTERFACE
MODULES AND
RELAY BASES
CTBP0115
Moulding
UL94-V0 flame retardant PA66
Pin/terminal
Tin plated brass
Wire protector
Screw/torque
Recommended PCB
hole size
Phosphor bronze, nickel plated
M2.5 Steel, zinc plated 0.4Nm
ø1.5mm
7.5
3.75
10.3
081
7. 5 m m p i t c h s t a n d a r d p r o f i l e 9 0 °
rising clamp terminal blocks
0.6
14.1
PCB TERMINAL
BLOCKS
4.5
K E Y F E AT U R E S
CONNECT
90 Degree orientation | Double interlock mechanism
40
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
FM 28614
EMS 613558
很抱歉,暂时无法提供与“CTBP0115/3”相匹配的价格&库存,您可以联系我们找货
