CTBP9550/2AO
CTBP9550/2AO
    CAMDENBOSS
    CAMDENBOSS - CTBP9550/2AO - Terminal Block, Header, 7.5 mm, 2 Ways, 20 A, 450 V, Through Hole Right ...
CTBP9550/2AO 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS 002 PCB TERMINAL BLOCKS 081 TERMINAL STRIPS 7. 5 m m p i t c h p l u g g a b l e r i s i n g c l a m p terminal blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS •  • • • • • • • • • • S P E C I F I C AT I O N 2-12 pole solid block Professional rising clamp terminals Moulded in green UL94-V0 flame retardant PA66 Cable acceptance - 0.32 to 1.6mm2 (28-14AWG) solid and stranded cable Pluggable male and female connectors Open and closed headers Horizontal female plug style Polarised mouldings Anti solder wicking Captive screws and guided pin alignment approved US , C Rating UL=15A/300V, VDE=20A/450V Insulation resistance 500M Ω/500V Withstand voltage AC2000V/1min Contact resistance 20mΩ (max) Working temperature -40°C to +105°C Moulding UL94-V0 flame retardant PA66 Pin/terminal Tin plated brass Rising clamp Brass, nickel plated Screw/torque M3 steel, zinc plated 0.5Nm Recommended PCB hole size ø1.7mm Female connector LENGTH 2 13mm CTBP9400/3 3 20.5mm CTBP9400/4 4 28mm CTBP9400/5 5 35.5mm CTBP9400/6 6 43mm CTBP9400/7 7 50.5mm CTBP9400/8 8 58mm CTBP9400/9 9 65.5mm CTBP9400/10 10 73mm CTBP9400/11 11 80.5mm CTBP9400/12 12 88mm CTBP9400 18.1 POLES CTBP9400/2 8.3 INTERFACE MODULES AND RELAY BASES PA R T N O . 7.5 15.05 158 PCB mounting male vertical connector (closed ended) LENGTH 2 15mm CTBP9500/3 3 22.5mm CTBP9500/4 4 30mm CTBP9500/5 5 37.5mm CTBP9500/6 6 45mm CTBP9500/7 7 52.5mm CTBP9500/8 8 60mm CTBP9500/9 9 67.5mm CTBP9500/10 10 75mm CTBP9500/11 11 82.5mm CTBP9500/12 12 90mm CTBP9500 7.5 7.8 3.9 1 4 POLES CTBP9500/2 12 PA R T N O . 8.5 CONNECT PCB mounting male horizontal connector (closed ended) 68 LENGTH 2 15mm CTBP9550/3 3 22.5mm CTBP9550/4 4 30mm CTBP9550/5 5 37.5mm CTBP9550/6 6 45mm CTBP9550/7 7 52.5mm CTBP9550/8 8 60mm CTBP9550/9 9 67.5mm CTBP9550/10 10 75mm CTBP9550/11 11 82.5mm CTBP9550/12 12 90mm CTBP9550 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 4 7.8 12 POLES CTBP9550/2 2 PA R T N O . 8.5 7.5 1 SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS PCB mounting male vertical connector (open ended) LENGTH 2 13mm CTBP9500/3AO 3 20.5mm CTBP9500/4AO 4 28mm CTBP9500/5AO 5 35.5mm CTBP9500/6AO 6 43mm CTBP9500/7AO 7 50.5mm CTBP9500/8AO 8 58mm CTBP9500/9AO 9 65.5mm CTBP9500/10AO 10 73mm CTBP9500/11AO 11 80.5mm CTBP950012AO 12 88mm CTBP9500 AO 7.5 7.8 1 4 POLES CTBP9500/2AO 081 TERMINAL STRIPS 3.9 12 PA R T N O . 095 WIRE TO BOARD CONNECTORS 8.5 100 CIRCULAR CONNECTORS 151 PCB mounting male horizontal connector (open ended) IP68 CONNECTORS 13mm CTBP9550/3AO 3 20.5mm CTBP9550/4AO 4 28mm CTBP9550/5AO 5 35.5mm CTBP9550/6AO 6 43mm CTBP9550/7AO 7 50.5mm CTBP9550/8AO 8 58mm CTBP9550/9AO 9 65.5mm CTBP9550/10AO 10 73mm CTBP9550/11AO 11 80.5mm CTBP9550/12AO 12 88mm CTBP9550 AO 4 7.8 INTERFACE MODULES AND RELAY BASES 8.5 7.5 158 1 CONNECT LENGTH 2 12 POLES CTBP9550/2AO 2 PA R T N O . +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 69
CTBP9550/2AO 价格&库存
很抱歉,暂时无法提供与“CTBP9550/2AO”相匹配的价格&库存,您可以联系我们找货
