CBHEX1-PI3-GY
CBHEX1-PI3-GY
    CAMDENBOSS
    CAMDENBOSS - CBHEX1-PI3-GY - Enclosure, 146 mm x 130 mm x 45 mm, Grey, ABS, Raspberry Pi 3 Boards
CBHEX1-PI3-GY 数据手册
D E V E LO P M E N T B OA R D E N C LO S U R E S 268 HANDHELD DIECASTCASES ACCESSORIES 292 UNIVERSAL PLASTIC ENCLOSURES 317 HEAVY DUTY AND ELECTRICAL ENCLOSURES 3 41 DEVELOPMENT Hex-Box Pi 3 Ready Enclosure Product overview This UK manufactured Hex-Box Pi 3 Ready Enclosure has been designed with customisation and user flexibility at heart. The 100% recyclable housing features seven self-retaining panels, two of which have been customised to accommodate Raspberry Pi boards. The power cable panel and the remaining panels can be placed in your desired position. The design features and modern aesthetic create the perfect enclosure for Pi projects (when paired with the wall mount bracket) or desktops (when paired with the rubber feet), each sold separately. Raspberry Pi board not included. BOARD ENCLOSURES 369 Key features PCB mounting in the top and base Six bosses in the top, four in the base with Raspberry Pi VERSATILE IOT AND SENSOR ENCLOSURES mountable footprint Number index in base Aids wall mounting Self-retaining removable end panels Two pre-customised panels to allow for Raspberry Pi connections to be made. One spare panel to replace the power cable panel if using PoE. Smooth bevelled lid with flat top Suitable for a 2.5” screen and perfect for digital printing R A N G E S P E C I F I C AT I O N STANDARD UNIT INCLUDES MATERIALS P L AST I C E N C LOS U R E S COLOURS 344 Base, top, 7 x panels, 3 x 16mm thread forming (Pozi CSK) screws, 4 x No.4 x 1/4” Pozi Pan Base UL94-V0 ABS Top UL94-V0 ABS Screws BZP (Bright Zinc Plated Steel) Grey RAL7047 Black RAL9005 White RAL9003 COMPLIANCE RoHS compliant OPERATING TEMPERATURE -10°C to +80°C TEST RESULTS SCREW TORQUE PURCHASING INFORMATION OPTIONS Standard Test Result Test report EN 62262 Impact test IK07 TR112 BS EN 60529 IP code IP30 TR110 Pozi csk screws 0.3Nm Country of origin Great Britain (GB) Commodity code 3923101000 Weight 120g Enclosure type Versatile sensor and IoT enclosures For alternative colours and materials MOQs will apply DESCRIPTION GREY (GY) B L AC K ( B K ) WHITE (WH) 1 x enclosure, 2 x customised solid panels to accommodate Raspberry Pi3, 2 x solid panel and 3 x vented panels CBHEX1-PI3-GY CBHEX1-PI3-BK CBHEX1-PI3-WH E N C LO S U R E D I M E N S I O N S ( L x Wx H ) EXTERNAL INTERNAL WA L L T H I C K N E S S 146 x 130 x 45 mm 122.5 x 125.5 x 34.5 mm 2.5 mm H L W Potential industries / applications Smart home, smart office, portable computer, networking projects, Pi camera, Pi screen, IoT +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 D E V E LO P M E N T B OA R D E N C LO S U R E S 268 HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES Desk Mount Accessory 292 UNIVERSAL PLASTIC ENCLOSURES Rubber feet Product overview 317 The six rubber feet (CBHEX-FEET) turn your Hex-Box IoT Enclosure into a tabletop enclosure. Simply push the feet into the holes in the base of the Hex-Box IoT Enclosure. HEAVY DUTY AND ELECTRICAL ENCLOSURES RUBBER FEET (6PCS) 3 41 DEVELOPMENT CBHEX-FEET BOARD ENCLOSURES Wa l l M o u n t Accessory 369 VERSATILE IOT AND SENSOR ENCLOSURES C i r c u l a r Wa l l M o u n t B r a c k e t Product overview Transform your Hex-Box IoT Pi Enclosure into a wall mountable enclosure with the Circular Wall Mount Bracket. This revolutionary circular mounting bracket is packed full of mounting options and offers seamless and discrete mounting to retain the modern aesthetic look of your housing, whilst gaining additional functionality. Key features 2 x keyhole mounting slots Allow for quick and easy wall mounting Raised rib standoffs Help with stability of the enclosure on uneven walls 2 x sets of UK single gang back box mounting points In two off centre orientations 25mm cable entry knockout for cable management Customisation required to the enclosure base, using the guide provided Easy installation Screw the lugs to the enclosure, twist 30 degrees and your bracket is attached 4 x static mount points/slots Provides easy and flexible wall mount fitting R A N G E S P E C I F I C AT I O N DIAMETER PURCHASING INFORMATION UL94-V0 ABS Wall mount lugs UL94-V0 ABS Screws BZP (Bright Zinc Plated Steel) C I R C U L A R WA L L M O U N T B R A C K E T GREY (GY) B L AC K (BK) WHITE (WH) CBWMC-GY CBWMC-BK CBWMC-WH INCLUDED 1 x circular wall mount bracket, 3 x screws, 3 x lugs P L AST I C E N C LOS U R E S MATERIAL Wall mount bracket 98.3 mm Country of origin Great Britain (GB) Commodity code 3923101000 Weight 23.6g +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 Vers21 Vers 345
CBHEX1-PI3-GY 价格&库存
很抱歉,暂时无法提供与“CBHEX1-PI3-GY”相匹配的价格&库存,您可以联系我们找货
