CCB2S1/07
CCB2S1/07
    CAMDENBOSS
    CAMDENBOSS - CCB2S1/07 - Circular Connector, IP68, CamCirc CCB Series, Panel Mount Receptacle, 7 Con...
CCB2S1/07 数据手册
CIRCULAR CONNECTORS PLUGS SOCKETS ACC E SS O R I E S 002 PCB TERMINAL DIECAST BLOCKS ACCESSORIES 081 TERMINAL STRIPS 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS 158 Push-pull connectors female fixed socket CCB series CCB2S1/07 7 pole CCB2S1/07 • Premium range of circular connectors • IP68 sealed using vacuum technology (when connected and using environmental cable clamp) • Tough, high performance interconnection solution • Compact panel mounting design • Ideal for harsh and extreme environments • Suitable for broadcasting, autosport, military, rail, marine, security, industrial and agricultural applications • Key coded to prevent misconnection • Will not disconnect when the cable is under load or stress • Tested to IEC 60512-3-5a S P E C I F I C AT I O N Shell style/model D type fixed socket, female contact Codes Code 1 Contact type Solder type Contact diameter 0.7mm Max. stranded conductor AWG 21-22 Max diameter 0.79mm Vtest (contact-shell) 1000V(AC) 2000V(DC) Vtest (contact-contact) 1300V(AC) 2000V(DC) Rated current 5.0A Rated voltage ≤250V PA R T N O . DESCRIPTION POLES SERIES Mechanical operation 5000 mating cycles CCB2S1/07 Female fixed socket 07 CCB series Housing material Brass (natural chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Insulator PPS Contacts Brass (gold plated) Humidity (max) 72 hr Climatical category 50/175/21 Shielding (min) 75 dB (10 MHz) Shielding (min) 40 dB (1 GHz) IP rating IP68 (when connected and using environmental cable clamp) INTERFACE MODULES AND RELAY BASES 23 0 min - 8 max Ø14 M12*1.0 1.5 14 K E Y F E AT U R E S Key coded | Panel mounting socket | Flat face ACC E SS O R I E S Metal and rubber caps for sockets | Low profile PA R T N O . DESCRIPTION CCT21 Camcirc metal cap for sockets A2 PA R T N O . DESCRIPTION CCT22 Camcirc rubber cap for sockets A2 CONNECT A S S O C I AT E D P R O D U C T S 136 C C A 2 P 1 /A 0 7 - C C A S e r i e s A 2 s i z e p l u g page 111 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614
CCB2S1/07 价格&库存
很抱歉,暂时无法提供与“CCB2S1/07”相匹配的价格&库存,您可以联系我们找货
