CCM1S1/05
CCM1S1/05
    CAMDENBOSS
    CAMDENBOSS - CCM1S1/05 - Circular Connector, IP68, CamCirc CCM Series, Panel Mount Receptacle, 5 Con...
CCM1S1/05 数据手册
ACC E SS O R I E S SOCKETS PLUGS CIRCULAR CONNECTORS 002 PCB TERMINAL DIECAST DIECAST BLOCKS ACCESSORIES ACCESSORIES Push-pull connectors female fixed socket CCM series CCM1S1/05 5 pole CCM1S1/05 • Premium range of circular connectors • IP68 sealed using vacuum technology (when connected and using environmental cable clamp) • Tough, high performance interconnection solution • Compact panel mounting design • Ideal for harsh and extreme environments • Suitable for broadcasting, autosport, military, rail, marine, security, industrial and agricultural applications • Key coded to prevent misconnection • Will not disconnect when the cable is under load or stress • Tool slots for secure and tight mounting • Tested to IEC 60512-3-5a 081 TERMINAL STRIPS S P E C I F I C AT I O N Shell style/model DEU type fixed socket, female contact Codes Code 1 Contact type Solder type Contact diameter 0.7mm Max. stranded conductor AWG 21-22 Max diameter 0.79mm Vtest (contact-shell) 800V(AC) 1300V(DC) Vtest (contact-contact) 1000V(AC) 1800V(DC) Rated current 5.2A Rated voltage ≤160V 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS PA R T N O . DESCRIPTION POLES SERIES Mechanical operation 5000 mating cycles CCM1S1/05 Female fixed socket 5 CCM series Housing material Brass (natural chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Insulator PPS Contacts Brass (gold plated) Humidity (max) 72 hr Climatical category 50/175/21 Shielding (min) 75 dB (10 MHz) Shielding (min) 40 dB (1 GHz) IP rating IP68 (when connected and using environmental cable clamp) 18.6 7.0 Ø14 8.6 6.5 158 INTERFACE MODULES AND RELAY BASES K E Y F E AT U R E S Key coded | Deep panel mounting socket ACC E SS O R I E S Metal and rubber caps for sockets | Face slots for tightening with a tool PA R T N O . DESCRIPTION CCT11 Camcirc metal cap for sockets A1 PA R T N O . DESCRIPTION CCT12 Camcirc rubber cap for sockets A1 C C A 1 P 1 /A 0 5 - C C A S e r i e s A 1 s i z e p l u g CONNECT A S S O C I AT E D P R O D U C T S page 104 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 Vers 1 123
CCM1S1/05 价格&库存
很抱歉,暂时无法提供与“CCM1S1/05”相匹配的价格&库存,您可以联系我们找货
