CHH66C1OR
CHH66C1OR
    CAMDENBOSS
CHH66C1OR 数据手册
H A N D H E L D E N C LOS U R E S 268 HANDHELD CASES 292 UNIVERSAL PLASTIC ENCLOSURES 317 HEAVY DUTY AND ELECTRICAL ENCLOSURES 341 DESKTOP AND INSTRUMENT CASES Call our sales team today on 01638 716101 or visit www.camdenboss.com 66 Series Rubber Corner Handheld Enclosures Product overview Advance your handheld electronic device with the 66 series range of handheld enclosures. This ergonomically designed innovative electronics enclosure is manufactured for quick and easy assembly. Available in a selection of sizes and colours, with the added option of a battery compartment. Moulded in high impact ABS, UL94-V0, the enclosure also features a choice of different coloured rubber corners for added protection. The corners are sold separately, enabling you to choose the colour to suit your requirements. They slide and catch in place to retain the enclosure halves together, allowing for quick and easy screwless assembly*. Key features 369 PCB mounting in the top and base VERSATILE IOT AND SENSOR ENCLOSURES Six bosses in the top, four in the base 2x self-retaining removable end panels Panels can be easily customised and are self retaining for ease of assembly 4x rubber corners in a choice of seven colours Slide on rubber corners allow for quick and easy screwless assembly and add increased protection Battery compartment option Choose between a standard enclosure or opt for a battery compartment Body type Enclosure is available in six different sizes, two different heights and two different colours. Gasket path Increase the IP rating with the optional gasket accessory Choose your enclosure I N D I V I D U A L S I Z E S P E C I F I C AT I O N B L AC K P L AST I C E N C LOS U R E S SIZE 272 WITHOUT B AT T E R Y DOOR GREY WITH B AT T E R Y DOOR WITHOUT B AT T E R Y DOOR WITH B AT T E R Y DOOR EXTERNAL DIMENSIONS (LXWXH) H 1 CHH661NBK CHH661BBK CHH661NGY CHH661BGY 145mm x 95mm x 25mm 2 CHH662NBK CHH662BBK CHH662NGY CHH662BGY 145mm x 95mm x 35mm 3 CHH663NBK CHH663BBK CHH663NGY CHH663BGY 185mm x 110mm x 25mm 4 CHH664NBK CHH664BBK CHH664NGY CHH664BGY 185mm x 110mm x 35mm 5 CHH665NBK CHH665BBK CHH665NGY CHH665BGY 200mm x 120mm x 25mm 6 CHH666NBK CHH666BBK CHH666NGY CHH666BGY 200mm x 120mm x 35mm L W Choose your rubber corners C H O O S E YO U R R U B B E R C O R N E R S CO LO U R TO FIT 25MM HIGH CASES TO FIT 35MM HIGH CASES BLUE CHH66C1BL CHH66C2BL GREEN CHH66C1GR CHH66C2GR RED CHH66C1RD CHH66C2RD ORANGE CHH66C1OR CHH66C2OR BLACK CHH66C1BK CHH66C2BK YELLOW CHH66C1YL CHH66C2YL GREY CHH66C1GY CHH66C2GY *Screws and nuts are required for the enclosure to be mains compliant +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 12 FM 28614 Call our sales team today on 01638 716101 or visit www.camdenboss.com H A N D H E L D E N C LOS U R E S 268 HANDHELD CASES 292 UNIVERSAL PLASTIC ENCLOSURES R A N G E S P E C I F I C AT I O N 1 x base, 1 x lid, 2 end panels Battery door option includes: Battery door and retaining screw (M3 x6mm Pozi CSK) STANDARD UNIT INCLUDES MATERIALS HARDWARE (NOT SUPPLIED) ENCLOSURE COLOURS TPE coated polypropylene 25mm enclosure M3 nut and 8mm pan screw 35mm enclosure M3 nut and 16mm pan screw Customisation options PCB screw No.2 (2.2mm) 1/4” (6.5mm) pan Digital printing, screen printing, machining / drilling and Grey RAL 7035 engraving. Black RAL 9004 Designed to meet the requirements of IP54 (IP65 with gasket) -10°C to 80°C Standard Test Result Test report UL94 Flammability V0 E248280 EN62262 Impact test IK08 TR114 Enclosure screw/nut 70Nm PCB screw 20Nm Country of origin China Commodity code 3923101000 Weight Size 1: 103g Size 2: 122g Size 3: 151g Enclosure type Handheld 341 DEVELOPMENT BOARD ENCLOSURES 369 VERSATILE IOT AND SENSOR ENCLOSURES OPERATING TEMPERATURE OPTIONS Handheld diagnostics equipment, control devices, voltmeters, sensor equipment, Mechanics, electrician marine, builders, surveyors. Rubber corners RoHS compliant PURCHASING INFORMATION HEAVY DUTY AND ELECTRICAL ENCLOSURES UL94-V0 ABS IP RATING SCREW TORQUE 317 Enclosure, lid & panels COMPLIANCE TEST RESULTS Potential industries / applications Size 4: 174g Size 5: 181g Size 6: 191g For alternative colours and materials MOQs will apply. P C B D I M E N S I O N S F O R E N C LOS U R E S I Z E S SIZE MAX PCB DIMENSIONS (LXW) PCB MOUNTING POSITION 1 2 3 4 5 6 W I T H O U T B AT T E R Y C O M PA R T M E N T W I T H B AT T E R Y C O M PA R T M E N T LID 134mm x 70.16mm - BASE 134mm x 70.16mm 70.5mm x 70.16mm LID 134mm x 70.16mm - BASE 134mm x 70.16mm 70.5mm x 70.16mm LID 174.29mm x 84.34mm - BASE 174.29mm x 84.34mm 111mm x 84.34mm LID 174.29mm x 84.34mm - BASE 174.29mm x 84.34mm 111mm x 84.34mm LID 189mm x 94.86mm - BASE 189mm x 94.86mm 120mm x 94.86mm LID 189mm x 94.86mm - BASE 189mm x 94.86mm 120mm x 94.86mm P L AST I C E N C LOS U R E S Dimensions taken from edge-to-edge, corner obstructions need to be accounted for. Battery compartment accessory C L I P - I N B AT T E R Y C O M PA R T M E N T T Y P E PA R T N O . CO LO U R CHHBAT1BK PP3 Black CHHBAT1GY PP3 Grey CHHBAT2BK AA Black CHHBAT2GY AA Grey We a t h e r p r o o f g a s k e t a c c e s s o r y PA R T N O . CHH66GSKT DESCRIPTION 66 Series weatherproof gasket +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 Vers Vers21 273
CHH66C1OR
1. 物料型号:文档列出了不同尺寸和颜色的塑料外壳型号,例如CHH661NBK、CHHS61BBK等。 2. 器件简介:介绍了手持电子设备的手持外壳,这些外壳设计用于快速简易组装,有多种尺寸和颜色可选,并可选择带电池仓的选项。 3. 引脚分配:文档中没有明确提到引脚分配。 4. 参数特性:外壳材质为UL94-V0 ABS,工作温度范围为-10°C至80°C,符合RoHS标准,设计满足IP4防护等级(带密封条时为IP6)。 5. 功能详解:外壳具有自锁式可拆卸端板、橡胶角、电池仓选项等特性。 6. 应用信息:适用于手持诊断设备、控制设备、万用表、传感器设备等。 7. 封装信息:提供了不同尺寸的外壳的外部尺寸和内部尺寸,以及电池仓的尺寸。
CHH66C1OR 价格&库存
很抱歉,暂时无法提供与“CHH66C1OR”相匹配的价格&库存,您可以联系我们找货
