H A N D H E L D E N C LOS U R E S
268
HANDHELD CASES
292
UNIVERSAL
PLASTIC
ENCLOSURES
317
HEAVY DUTY
AND ELECTRICAL
ENCLOSURES
341
DESKTOP AND
INSTRUMENT
CASES
Call our sales team today on 01638 716101 or visit www.camdenboss.com
66 Series Rubber Corner Handheld
Enclosures
Product overview
Advance your handheld electronic device with the 66 series range of
handheld enclosures. This ergonomically designed innovative electronics
enclosure is manufactured for quick and easy assembly. Available in
a selection of sizes and colours, with the added option of a battery
compartment. Moulded in high impact ABS, UL94-V0, the enclosure also
features a choice of different coloured rubber corners for added protection.
The corners are sold separately, enabling you to choose the colour to suit
your requirements. They slide and catch in place to retain the enclosure
halves together, allowing for quick and easy screwless assembly*.
Key features
369
PCB mounting in the top and base
VERSATILE IOT
AND SENSOR
ENCLOSURES
Six bosses in the top, four in the base
2x self-retaining removable end panels
Panels can be easily customised and are self retaining for ease of
assembly
4x rubber corners in a choice of seven colours
Slide on rubber corners allow for quick and easy screwless
assembly and add increased protection
Battery compartment option
Choose between a standard enclosure or opt for a battery
compartment
Body type
Enclosure is available in six different sizes, two different heights and
two different colours.
Gasket path
Increase the IP rating with the optional gasket accessory
Choose your enclosure
I N D I V I D U A L S I Z E S P E C I F I C AT I O N
B L AC K
P L AST I C E N C LOS U R E S
SIZE
272
WITHOUT
B AT T E R Y
DOOR
GREY
WITH
B AT T E R Y
DOOR
WITHOUT
B AT T E R Y
DOOR
WITH
B AT T E R Y
DOOR
EXTERNAL DIMENSIONS
(LXWXH)
H
1
CHH661NBK
CHH661BBK
CHH661NGY
CHH661BGY
145mm x 95mm x 25mm
2
CHH662NBK
CHH662BBK
CHH662NGY
CHH662BGY
145mm x 95mm x 35mm
3
CHH663NBK
CHH663BBK
CHH663NGY
CHH663BGY
185mm x 110mm x 25mm
4
CHH664NBK
CHH664BBK
CHH664NGY
CHH664BGY
185mm x 110mm x 35mm
5
CHH665NBK
CHH665BBK
CHH665NGY
CHH665BGY
200mm x 120mm x 25mm
6
CHH666NBK
CHH666BBK
CHH666NGY
CHH666BGY
200mm x 120mm x 35mm
L
W
Choose your rubber corners
C H O O S E YO U R R U B B E R C O R N E R S
CO LO U R
TO FIT 25MM HIGH CASES
TO FIT 35MM HIGH CASES
BLUE
CHH66C1BL
CHH66C2BL
GREEN
CHH66C1GR
CHH66C2GR
RED
CHH66C1RD
CHH66C2RD
ORANGE
CHH66C1OR
CHH66C2OR
BLACK
CHH66C1BK
CHH66C2BK
YELLOW
CHH66C1YL
CHH66C2YL
GREY
CHH66C1GY
CHH66C2GY
*Screws and nuts are required for the enclosure to be mains compliant
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 12
FM 28614
268
HANDHELD CASES
292
UNIVERSAL
PLASTIC
ENCLOSURES
R A N G E S P E C I F I C AT I O N
1 x base, 1 x lid, 2 end panels
Battery door option includes:
Battery door and retaining screw (M3 x6mm Pozi CSK)
STANDARD UNIT INCLUDES
MATERIALS
HARDWARE
(NOT SUPPLIED)
ENCLOSURE COLOURS
TPE coated polypropylene
25mm enclosure
M3 nut and 8mm pan screw
35mm enclosure
M3 nut and 16mm pan screw
Customisation options
PCB screw
No.2 (2.2mm) 1/4” (6.5mm) pan
Digital printing, screen printing, machining / drilling and
Grey
RAL 7035
engraving.
Black
RAL 9004
Designed to meet the requirements of IP54 (IP65 with gasket)
-10°C to 80°C
Standard
Test
Result
Test report
UL94
Flammability
V0
E248280
EN62262
Impact test
IK08
TR114
Enclosure screw/nut
70Nm
PCB screw
20Nm
Country of origin
China
Commodity code
3923101000
Weight
Size 1: 103g
Size 2: 122g
Size 3: 151g
Enclosure type
Handheld
341
DEVELOPMENT
BOARD
ENCLOSURES
369
VERSATILE IOT
AND SENSOR
ENCLOSURES
OPERATING TEMPERATURE
OPTIONS
Handheld diagnostics equipment, control devices,
voltmeters, sensor equipment, Mechanics, electrician
marine, builders, surveyors.
Rubber corners
RoHS compliant
PURCHASING INFORMATION
HEAVY DUTY
AND ELECTRICAL
ENCLOSURES
UL94-V0 ABS
IP RATING
SCREW TORQUE
317
Enclosure, lid & panels
COMPLIANCE
TEST RESULTS
Potential industries /
applications
Size 4: 174g
Size 5: 181g
Size 6: 191g
For alternative colours and materials MOQs will apply.
P C B D I M E N S I O N S F O R E N C LOS U R E S I Z E S
SIZE
MAX PCB DIMENSIONS (LXW)
PCB
MOUNTING
POSITION
1
2
3
4
5
6
W I T H O U T B AT T E R Y
C O M PA R T M E N T
W I T H B AT T E R Y
LID
134mm x 70.16mm
BASE
134mm x 70.16mm
70.5mm x 70.16mm
LID
134mm x 70.16mm
BASE
134mm x 70.16mm
70.5mm x 70.16mm
LID
174.29mm x 84.34mm
BASE
174.29mm x 84.34mm
111mm x 84.34mm
LID
174.29mm x 84.34mm
BASE
174.29mm x 84.34mm
111mm x 84.34mm
LID
189mm x 94.86mm
BASE
189mm x 94.86mm
120mm x 94.86mm
LID
189mm x 94.86mm
BASE
189mm x 94.86mm
120mm x 94.86mm
Dimensions taken from edge-to-edge, corner obstructions need to be accounted for.
Battery compartment accessory
C L I P - I N B AT T E R Y
C O M PA R T M E N T T Y P E
PA R T N O .
CO LO U R
CHHBAT1BK
PP3
Black
CHHBAT1GY
PP3
Grey
CHHBAT2BK
AA
Black
CHHBAT2GY
AA
Grey
We a t h e r p r o o f g a s k e t a c c e s s o r y
PA R T N O .
CHH66GSKT
DESCRIPTION
66 Series weatherproof gasket
FM 28614
Vers
Vers21
273
很抱歉,暂时无法提供与“CHHBAT1GY”相匹配的价格&库存,您可以联系我们找货
