CSM40580E
CSM40580E
    CAMDENBOSS
CSM40580E 数据手册
MICROSWITCHES 178 MICROSWITCHES 182 TACTILE SWITCHES V4 type sub miniature microswitches 5A Product overview 186 22MM CONTROL SWITCHES 191 FOOT SWITCHES CSM405 S P E C I F I C AT I O N • Rating 5A switching S.P.D.T. (10A to order) • Long life coil spring mechanism • Solder, PCB, 90° PCB mounting or 2.8mm quick connect terminals • Button, lever or roller actuators • Anti-solder wicking US approved • C Rating 5A/250VAC (10A to order) Contact resistance 50mΩ max Insulation strength 100MΩ min/500VDC Electrical life 50,000 operations min Temperature range -10°C to +125°C Material Case Button Actuator Contacts Teminals Brass alloy H65 silver plated PBT PPS Stainless steel AgNi10-Cu 193 LIMIT SWITCHES 5A 203 PIEZO SWITCHES AND KEYPADS O P E R AT I N G FORCE MAX A C T U AT O R S T Y L E RELEASE FORCE MAX O P E R AT I N G POSITION P R E T R AV E L MAX M OV E M E N T DIFFERENTIAL O V E R T R AV E L MIN CSM40500- Button 1.5N 0.3N 8.6 ± 0.4mm 0.8mm 0.2mm 0.5mm CSM40510- Short lever 0.25N 0.04N 8.9 ± 1mm 4.6mm 0.8mm 0.8mm CSM40520- Standard lever 0.25N 0.06N 8.9 ± 1mm 5mm 0.8mm 1.2mm CSM40530- Long lever 0.2N 0.03N 9.6 ± 2mm 7.5mm 1.5mm 1.6mm CSM40540- Simulated roller 0.25N 0.04N 12 ± 1.2mm 4.7mm 0.8mm 1.2mm CSM40550- Standard roller 0.25N 0.04N 15.2 ± 1mm 4.8mm 0.9mm 1.2mm CSM40580- Extra long lever 0.1N 0.02N 9.8 ± 1.5mm 8mm 2.5mm 1.5mm *Please add suffix for terminal type (eg CSM40540E - 5A simulated roller type with 2.8mm) quick connect terminals Types of terminal Types of actuator Simulated roller Button actuator Suffix E Suffix A Suffix F Suffix G 3.6 7 9.5 10.6 3.6 2.8 3.2 Solder 3.2 PCB mount 2.8mm quick connect 8.8 3.6 0.6 3.6 0.6 7.3 8.8 16.1 90° PCB mount 19.8 Long lever Short lever 9.5 2.3 2.3 1.2 1.2 10.6 0.4 2.3 4.7 10.6 7.1 4 15.2 6.4 6.40 4 22.60±1.50 16.1 19.8 0.4 7.3 14.5 3.2 Standard roller 14 4.8 4 2.50 9.50 10.60 10.6 0.4 2.3 2.35 9.5 C NO NC 3.60 3.6 2.3 8.8 9.5 10.6 2.3 2.90 0.60 TYP 8.80 0.6 7.3 2.35 9.5 5.15 OP 0.40 3.6 1.60 7.30 0.4 3.20 8.8 =16.10= 16.1 19.80 19.8 19.8 Extra long lever 6.40 42 9.50 2.35 2.35 SWITCH 5.15 9.5 8.80 0.40 2.90 3.20 7.30 =16.10= 19.80 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers21 9.50 C NO NC 3.60 1.60 0.60TYP OP 2.50 2.35 NC NO C 3.60 180 10.60 OP 6.40 4 Standard lever 4 2.50 10.60 0.6 7.3 16.1 0.40 2.35 5.15 0.60TYP 9.50 7.30 8.80 =16.10= 19.80 2.90 1.60 3.20
CSM40580E 价格&库存
很抱歉,暂时无法提供与“CSM40580E”相匹配的价格&库存,您可以联系我们找货
