CSTBP45VDB/3
CSTBP45VDB/3
    CAMDENBOSS
    CAMDENBOSS - CSTBP45VDB/3 - Wire-To-Board Terminal Block, 3.5 mm, 3 Ways, 28 AWG, 16 AWG, 1.3 mm², P...
CSTBP45VDB/3 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D SCREWLESS PLUGGABLES 002 PCB TERMINAL BLOCKS 081 TERMINAL STRIPS 3.5mm 45° screwless terminal blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS • • • • • • • • • • S P E C I F I C AT I O N Interlocking modules Easily breakable to desired number of poles 45° cable entry Kinked pins for soldering retention Guided pin alignment Offset pinout allows greater voltage clearance Choice of 2 pin positions Moulded in green UL94-V0 PA66 0.34-0.75mm2 cable (22-18AWG) US approved C Rating 10A/300V Insulation withstand voltage AC2000V/1 min Insulation resistance 500MΩ at DC500V Operating temperature -40°C to +105°C Moulding UL94-V0 PA66 Pin/contact Tin plated phosphor bronze Recommended PCB hole size 1.2mm 151 IP68 CONNECTORS 6 22.6mm CSTBP45VDA/7 7 26.1mm CSTBP45VDA/8 8 29.6mm CSTBP45VDA/9 9 33.1mm CSTBP45VDA/10 10 36.6mm CSTBP45VDA/11 11 40.1mm CSTBP45VDA/12 12 43.6mm PA R T N O . POLES LENGTH CSTBP45VDB/2 2 8.6mm CSTBP45VDB/3 3 12.1mm CSTBP45VDB/4 4 15.6mm CSTBP45VDB/5 5 19.1mm CSTBP45VDB/6 6 22.6mm CSTBP45VDB/7 7 26.1mm CSTBP45VDB/8 8 29.6mm CSTBP45VDB/9 9 33.1mm CSTBP45VDB/10 10 36.6mm CSTBP45VDB/11 11 40.1mm CSTBP45VDB/12 12 43.6mm TYPE A 0.40 0.8 5.00 4.8 3.5 3.4 N*3.5+1.6 1.6 0.40 5.00 4.8 3.5 3.4 TYPE B CONNECT | 45 degree modular design +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 2 1 0.8 NO.1 K E Y F E AT U R E S 86 1.75 CSTBP45VDB D u a l r o w p i n s | Tw o t y p e s o f p i n l a y o u t 12.0 CSTBP45VDA/6 NO.1 4±0.2 19.1mm 4±0.2 15.6mm 5 12.0 4 CSTBP45VDA/5 1.6 7.0 CSTBP45VDA/4 N*3.5+1.6 4±0.2 12.1mm 7.0 3 4±0.2 CSTBP45VDA/3 CSTBP45VDA 11.4 8.6mm 11.4 LENGTH 2 13.1 INTERFACE MODULES AND RELAY BASES POLES CSTBP45VDA/2 13.1 158 PA R T N O . 1.75
CSTBP45VDB/3 价格&库存
很抱歉,暂时无法提供与“CSTBP45VDB/3”相匹配的价格&库存,您可以联系我们找货
