CTB0305/3
CTB0305/3
    CAMDENBOSS
CTB0305/3 数据手册
PCB TERMINAL BLOCKS 3.5mm Pitch Ultra Low Profile Rising Clamp Terminal • • • • • • • • • • • 2-12 pole interlocking 4-12 pole pre-assembled Ultra low profile Moulded in green UL94-V0 flame retardant PA Professional rising clamp terminals 0.2-1.5mm2 (30-16AWG) solid cable 0.2-1.0mm2 (30-16AWG) stranded cable Captive screws Guided pin alignment Double interlock mechanism for increased strength , , approved CTB0305 PCB TERMINAL BLOCKS SPECIFICATION Rating Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Rising Clamp Screw/torque Recommended PCB hole size TYPE NO. CTB0305/2 CTB0305/3 CTB0305/4 CTB0305/5 CTB0305/6 CTB0305/7 CTB0305/8 CTB0305/9 CTB0305/10 CTB0305/11 CTB0305/12 POLES 2 3 4 5 6 7 8 9 10 11 12 10A/160V UL=10A/300V, VDE&IMQ=10A/130V ≥1.25kV 2.5kV 110°C UL94-V0 flame retardant PA66 Tinned, nickel plated brass Tinned, nickel plated brass M2 steel zinc plated, 0.3Nm ø1.1mm INTERCONNECTION FUSES & FUSEHOLDERS LEDs & INDICATORS LENGTH 7mm 10.5mm 14mm 17.5mm 21mm 24.5mm 28mm 31.5mm 35mm 38.5mm 42mm MINIATURE SWITCHES LIMIT & SAFETY SWITCHES CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES BATTERIES SOLAR PANELS TRANSFORMERS +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Ver 1.1
CTB0305/3 价格&库存
很抱歉,暂时无法提供与“CTB0305/3”相匹配的价格&库存,您可以联系我们找货
