CTB0502/2
CTB0502/2
    CAMDENBOSS
    Conn Terminal Block 2 POS 5mm Solder ST Thru-Hole 10A ; Region : ACNA
CTB0502/2 数据手册
CAMBLOCK 5mm Pitch Low Profile Rising Clamp Terminal Blocks • 2-12 pole double Interlocking mechanism for increased strength • 4-12 pole solid block and end stackable • Moulded in green UL94-V0 flame retardant PA66 • Professional rising clamp terminals • 0.128mm²-1.23mm2 (26- 16AWG) solid cable/ stranded cable • Captive screws • C US approved LENGTH 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 10A/300V 5000M Ω/1000V AC1500V/1min 20mΩ (max) -33°C to 120+°C UL94-V0 flame retardant PA66 M2.5 steel, nickel plated 0.4Nm ø1.4mm PCB TERMINAL BLOCKS 8.1 5x (p-1) 5.41 0.5 0.5 0.7 5 2.54 �1.0 - �1.1 4.05 5 xP POLES 2 3 4 5 6 7 8 9 10 11 12 SPECIFICATION Rating Insulation resistance Withstand voltage Contact resistance Working temperature Mouldings Screw/torque Recommended PCB hole size 3.5 TYPE NO. CTB0502/2 CTB0502/3 CTB0502/4 CTB0502/5 CTB0502/6 CTB0502/7 CTB0502/8 CTB0502/9 CTB0502/10 CTB0502/11 CTB0502/12 CTB0502 4.05 8.1 +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Ver 1 8.1 13
CTB0502/2 价格&库存
很抱歉,暂时无法提供与“CTB0502/2”相匹配的价格&库存,您可以联系我们找货
