CTB55VK/2
CTB55VK/2
    CAMDENBOSS
CTB55VK/2 数据手册
PCB TERMINAL BLOCKS 7.5mm Pitch Commercial Low Profile Screw Terminal Blocks • 2  & 3 pole solid block • End stackable • Moulded in green UL94-V0 flame retardant PA66 • Wire protector terminals • 0.5-4.0mm2 (30-12AWG) solid cable • 0.5-2.5mm2 (30-12AWG) stranded cable • Captive screws • Anti solder wicking terminal • Guided pin alignment • , , approved SPECIFICATION Rating CTB55VK Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Wire Protector Screw/torque Recommended PCB hole size PCB TERMINAL BLOCKS 24A/500V UL=16A/300V, VDE&IMQ=24A/750V 3kV 6kV 110°C UL94-V0 flame retardant PA66 Tinned, nickel plated brass Tin plated, phosphor bronze M2.5 steel zinc plated, 0.4Nm ø1.3mm INTERCONNECTION FUSES & FUSEHOLDERS LEDs & INDICATORS TYPE NO. CTB55VK/2 CTB55VK/3 POLES 2 3 LENGTH 15mm 22.5mm MINIATURE SWITCHES LIMIT & SAFETY SWITCHES CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES BATTERIES SOLAR PANELS TRANSFORMERS +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Ver 1.1
CTB55VK/2 价格&库存
很抱歉,暂时无法提供与“CTB55VK/2”相匹配的价格&库存,您可以联系我们找货
