PCB TERMINAL BLOCKS
10.16mm Pitch Very High Power Rising Clamp Terminal Blocks
• 2 & 3 pole double
interlocking mechanism for
increased strength
• 4 to 12 pole solid block
• Captive screws
• Moulded in grey UL94-V0
flame retardant PA66
• Professional rising
clamp terminals
• 0.5-16mm2 (20-6AWG)
solid cable
• 0.5-10mm2 (20-6AWG)
stranded cable
, , approved
SPECIFICATION
Rating
CTB77VP
Dielectric strength
Impulse withstand voltage
Working temperature
Moulding
Pin/terminal
Rising clamp
Screw/torque
Recommended PCB hole size
57A/630V
UL=58A/300V, VDE&IMQ=57A/750V
≥3kV
8kV
110°C
UL94-V0 flame retardant PA66
Tinned, nickel plated brass
Zinc plated steel
M4 steel zinc plated, 1.8Nm
ø1.6mm
PCB
TERMINAL
BLOCKS
INTERCONNECTION
FUSES &
FUSEHOLDERS
LEDs &
INDICATORS
TYPE NO.
CTB77VP/2
CTB77VP/3
CTB77VP/4
CTB77VP/5
CTB77VP/6
CTB77VP/7
CTB77VP/8
CTB77VP/9
CTB77VP/10
CTB77VP/11
CTB77VP/12
POLES
2
3
4
5
6
7
8
9
10
11
12
MINIATURE
SWITCHES
LENGTH
20.3mm
30.5mm
40.6mm
51mm
61mm
71.1mm
81.3mm
91.4mm
101.6mm
111.8mm
121.9mm
LIMIT &
SAFETY
SWITCHES
CONTROL
PRODUCTS
INTERFACE
MODULES &
SUPPORTS
RELAY
BASES
DIN RAIL
ENCLOSURES
BATTERIES
SOLAR
PANELS
TRANSFORMERS
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
We operate a constant improvement
policy, our products are subject to
change without notice.
Ver 1.1
很抱歉,暂时无法提供与“CTB77VP/3”相匹配的价格&库存,您可以联系我们找货
