CTB77VP/6
CTB77VP/6
    CAMDENBOSS
CTB77VP/6 数据手册
PCB TERMINAL BLOCKS 10.16mm Pitch Very High Power Rising Clamp Terminal Blocks • 2 & 3 pole double interlocking mechanism for increased strength • 4 to 12 pole solid block • Captive screws • Moulded in grey UL94-V0 flame retardant PA66 • Professional rising clamp terminals • 0.5-16mm2 (20-6AWG) solid cable • 0.5-10mm2 (20-6AWG) stranded cable • , , approved SPECIFICATION Rating CTB77VP Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size 57A/630V UL=58A/300V, VDE&IMQ=57A/750V ≥3kV 8kV 110°C UL94-V0 flame retardant PA66 Tinned, nickel plated brass Zinc plated steel M4 steel zinc plated, 1.8Nm ø1.6mm PCB TERMINAL BLOCKS INTERCONNECTION FUSES & FUSEHOLDERS LEDs & INDICATORS TYPE NO. CTB77VP/2 CTB77VP/3 CTB77VP/4 CTB77VP/5 CTB77VP/6 CTB77VP/7 CTB77VP/8 CTB77VP/9 CTB77VP/10 CTB77VP/11 CTB77VP/12 POLES 2 3 4 5 6 7 8 9 10 11 12 MINIATURE SWITCHES LENGTH 20.3mm 30.5mm 40.6mm 51mm 61mm 71.1mm 81.3mm 91.4mm 101.6mm 111.8mm 121.9mm LIMIT & SAFETY SWITCHES CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES BATTERIES SOLAR PANELS TRANSFORMERS +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Ver 1.1
CTB77VP/6 价格&库存
很抱歉,暂时无法提供与“CTB77VP/6”相匹配的价格&库存,您可以联系我们找货
