CAMBLOCK
5mm Pitch Pluggable Rising Clamp Terminal Blocks
PCB
TERMINAL
BLOCKS
• 2-24 pole solid block
• Pluggable male-female
connectors
• Open & closed headers
• Horizontal & vertical
female plug styles
• Polarised mouldings
• Moulded in green UL94-V0
flame retardant PA66
• Professional rising
clamp terminals
• 0.2-3.3mm2 (24-12AWG)
solid & stranded cable
• Captive screws
• Guided pin alignment
• C US approved
SPECIFICATION
Rating
Insulation resistance
Withstand voltage
Contact resistance
Working temperature
Mouldings
Wire protector
Screw/torque
Recommended PCB hole size
15A 300V
1000M Ω/1000V
AC1000V/1min
20m Ω
-40°C to +105°C
UL94-V0 flame retardant PA66
Tin plated, phosphor bronze
M3 steel, tin plated 0.4Nm
ø1.4mm
Female Connector
CTB9202/8
CTB9202/9
CTB9202/10
CTB9202/11
CTB9202/12
CTB9202/13
CTB9202/14
CTB9202/15
CTB9202/16
CTB9202/17
CTB9202/18
CTB9202/19
CTB9202/20
CTB9202/21
CTB9202/22
CTB9202/23
CTB9202/24
POLES
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
LENGTH
10mm
15mm
20mm
25mm
30mm
35mm
CTB9202
40mm
45mm
50mm
55mm
60mm
65mm
70mm
75mm
80mm
85mm
90mm
95mm
100mm
105mm
110mm
115mm
120mm
8.1
17.6
TYPE NO.
CTB9202/2
CTB9202/3
CTB9202/4
CTB9202/5
CTB9202/6
CTB9202/7
8.1
Female Connector Vertical (standard)
LENGTH
10mm
15mm
20mm
25mm
30mm
35mm
40mm
45mm
50mm
55mm
60mm
65mm
70mm
75mm
80mm
85mm
90mm
95mm
100mm
105mm
110mm
115mm
120mm
CTB922VG/S
We operate a constant improvement
policy, our products are subject to
change without notice.
50
EL EC T RO N IC S & ENC LOSURES
Ver 1
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
12.4
CTB922VG/14S
CTB922VG/15S
CTB922VG/16S
CTB922VG/17S
CTB922VG/18S
CTB922VG/19S
CTB922VG/20S
CTB922VG/21S
CTB922VG/22S
CTB922VG/23S
CTB922VG/24S
POLES
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25.9
TYPE NO.
CTB922VG/2S
CTB922VG/3S
CTB922VG/4S
CTB922VG/5S
CTB922VG/6S
CTB922VG/7S
CTB922VG/8S
CTB922VG/9S
CTB922VG/10S
CTB922VG/11S
CTB922VG/12S
CTB922VG/13S
CAMBLOCK
Female Connector Vertical (reversed)
LENGTH
10mm
15mm
20mm
25mm
30mm
35mm
40mm
45mm
50mm
55mm
60mm
65mm
70mm
75mm
80mm
85mm
90mm
95mm
100mm
105mm
110mm
115mm
120mm
CTB922VG/R
PCB
TERMINAL
BLOCKS
25.9
POLES
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
12.4
TYPE NO.
CTB922VG/2R
CTB922VG/3R
CTB922VG/4R
CTB922VG/5R
CTB922VG/6R
CTB922VG/7R
CTB922VG/8R
CTB922VG/9R
CTB922VG/10R
CTB922VG/11R
CTB922VG/12R
CTB922VG/13R
CTB922VG/14R
CTB922VG/15R
CTB922VG/16R
CTB922VG/17R
CTB922VG/18R
CTB922VG/19R
CTB922VG/20R
CTB922VG/21R
CTB922VG/22R
CTB922VG/23R
CTB922VG/24R
PCB Mounting Male Vertical (closed ended)
POLES
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
LENGTH
11.2mm
16.2mm
21.2mm
26.2mm
31.2mm
36.2mm
41.2mm
46.2mm
51.2mm
56.2
61.2mm
66.2mm
71.2mm
76.2mm
81.2mm
86.2mm
91.2mm
96.2mm
101.2mm
106.2mm
111.2mm
116.2mm
121.2mm
CTB9302
1.0x1.0
35.0±0.2
5.0
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
12.2±0.1
3.9±0.2
3.7
TYPE NO.
CTB9302/2
CTB9302/3
CTB9302/4
CTB9302/5
CTB9302/6
CTB9302/7
CTB9302/8
CTB9302/9
CTB9302/10
CTB9302/11
CTB9302/12
CTB9302/13
CTB9302/14
CTB9302/15
CTB9302/16
CTB9302/17
CTB9302/18
CTB9302/19
CTB9302/20
CTB9302/21
CTB9302/22
CTB9302/23
CTB9302/24
30.0
Ver 1
51
很抱歉,暂时无法提供与“CTB9202/4”相匹配的价格&库存,您可以联系我们找货
