CTB9358/10
CTB9358/10
    CAMDENBOSS
CTB9358/10 数据手册
PCB TERMINAL BLOCKS PCB mounting male horizontal (closed ended) TYPE NO. CTB9358/2 CTB9358/3 CTB9358/4 CTB9358/5 CTB9358/6 CTB9358/7 CTB9358/8 CTB9358/9 CTB9358/10 CTB9358/11 CTB9358/12 CTB9358/13 POLES 2 3 4 5 6 7 8 9 10 11 12 13 LENGTH 11.4mm 16.4mm 21.5mm 26.6mm 31.7mm 36.78mm 41.8mm 46.9mm 52mm 57.1mm 67.2mm 67.2mm TYPE NO. CTB9358/14 CTB9358/15 CTB9358/16 CTB9358/17 CTB9358/18 CTB9358/19 CTB9358/20 CTB9358/21 CTB9358/22 CTB9358/23 CTB9358/24 CTB9358 POLES 14 15 16 17 18 19 20 21 22 23 24 PCB TERMINAL BLOCKS LENGTH 72.3mm 77.4mm 82.5mm 87.6mm 92.6mm 97.7mm 102.8mm 107.9mm 113mm 118mm 123.1mm INTERCONNECTION FUSES & FUSEHOLDERS LEDs & INDICATORS PCB mounting male horizontal (open ended) TYPE NO. CTB9358/2AO CTB9358/3AO CTB9358/4AO CTB9358/5AO CTB9358/6AO CTB9358/7AO CTB9358/8AO CTB9358/9AO CTB9358/10AO CTB9358/11AO CTB9358/12AO CTB9358/13AO POLES 2 3 4 5 6 7 8 9 10 11 12 13 LENGTH 10.2mm 15.2mm 20.3mm 25.4mm 30.5mm 35.6mm 40.6mm 45.7mm 50.8mm 55.9mm 61mm 66mm TYPE NO. CTB9358/14AO CTB9358/15AO CTB9358/16AO CTB9358/17AO CTB9358/18AO CTB9358/19AO CTB9358/20AO CTB9358/21AO CTB9358/22AO CTB9358/23AO CTB9358/24AO POLES 14 15 16 17 18 19 20 21 22 23 24 LENGTH 71.1mm 76.2mm 81.3mm 86.4mm 91.4mm 96.5mm 101.6mm 106.7mm 111.7mm 116.8mm 121.9mm MINIATURE SWITCHES CTB9358/AO LIMIT & SAFETY SWITCHES CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES BATTERIES SOLAR PANELS TRANSFORMERS +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Ver 1.1
CTB9358/10 价格&库存
很抱歉,暂时无法提供与“CTB9358/10”相匹配的价格&库存,您可以联系我们找货
