CTB9359/3
CTB9359/3
    CAMDENBOSS
    PCB mounting male horizontal (closed end)
CTB9359/3 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS ECONOMY RANGE 5.08mm pitch pluggable rising clamp terminal blocks Product overview • • • • • • • • E CO N O M Y R A N G E P C B T E R M I N A L B LO C KS • • • 19 2-12 pole solid block Up to 24 poles available Pluggable male-female connectors Professional rising clamp terminals Closed headers Polarised mouldings Moulded in green UL94-V0 flame retardant PA66 0.33-2mm2 (22-14AWG) solid & stranded cable Captive screws Guided pin alignment approved PA R T N O . POLES LENGTH CTB9209/2 2 10.2mm CTB9209/3 3 15.2mm CTB9209/4 4 20.3mm CTB9209/5 5 25.4mm CTB9209/6 6 30.5mm CTB9209/7 7 35.6mm CTB9209/8 8 40.6mm CTB9209/9 9 45.7mm CTB9209/10 10 50.8mm CTB9209/11 11 55.9mm CTB9209/12 12 61mm PA R T N O . POLES LENGTH CTB922VJ/2S 2 10.2mm CTB922VJ/3S 3 15.2mm CTB922VJ/4S 4 20.3mm CTB922VJ/5S 5 25.4mm CTB922VJ/6S 6 30.5mm CTB922VJ/7S 7 35.6mm CTB922VJ/8S 8 40.6mm CTB922VJ/9S 9 45.7mm CTB922VJ/10S 10 50.8mm CTB922VJ/11S 11 55.9mm CTB922VJ/12S 12 61mm PA R T N O . POLES LENGTH CTB922VJ/2R 2 10.2mm CTB922VJ/3R 3 15.2mm CTB922VJ/4R 4 20.3mm CTB922VJ/5R 5 25.4mm CTB922VJ/6R 6 30.5mm CTB922VJ/7R 7 35.6mm CTB922VJ/8R 8 40.6mm CTB922VJ/9R 9 45.7mm CTB922VJ/10R 10 50.8mm CTB922VJ/11R 11 55.9mm CTB922VJ/12R 12 61mm S P E C I F I C AT I O N Rating 15A 300V Insulation resistance 1000M Ω/1000V Withstand voltage AC1000V/1min Contact resistance 20m Ω Working temperature -40°C to +105°C Mouldings UL94-V0 flame retardant PA66 Wire protector Tin plated, phosphor bronze Screw/torque M2.5 steel, tin plated 0.4Nm Recommended PCB hole size ø1.7mm CTB9209 CTB922VJ S CTB922VJ R +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 EMS 613558 SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS ECONOMY RANGE CTB9309/3 3 16.4mm CTB9309/4 4 21.5mm CTB9309/5 5 26.6mm CTB9309/6 6 31.7mm CTB9309/7 7 36.78mm CTB9309/8 8 41.8mm CTB9309/9 9 46.9mm CTB9309/10 10 52mm CTB9309/11 11 57.1mm CTB9309/12 12 62.3mm PA R T N O . POLES LENGTH TB9359/2 2 11.4mm CTB9359/3 3 16.4mm CTB9359/4 4 21.5mm CTB9359/5 5 26.6mm CTB9359/6 6 31.7mm CTB9359/7 7 36.78mm CTB9359/8 8 41.8mm CTB9359/9 9 46.9mm CTB9359/10 10 52mm CTB9359/11 11 57.1mm CTB9359/12 12 62.3mm PA R T N O . POLES LENGTH CTB9309/2AO 2 11.4mm CTB9309/3AO 3 16.4mm CTB9309/4AO 4 21.5mm CTB9309/5AO 5 26.6mm CTB9309/6AO 6 31.7mm CTB9309/7AO 7 36.78mm CTB9309/8AO 8 41.8mm CTB9309/9AO 9 46.9mm CTB9309/10AO 10 52mm CTB9309/11AO 11 57.1mm CTB9309/12AO 12 62.3mm CTB9309 12.2 CTB9359 12.1 CTB9309 AO E CO N O M Y R A N G E P C B T E R M I N A L B LO C KS 11.4mm 3.7 LENGTH 2 3.75 POLES CTB9309/2 7.82 PA R T N O . 8.23 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers 1 20
CTB9359/3 价格&库存
很抱歉,暂时无法提供与“CTB9359/3”相匹配的价格&库存,您可以联系我们找货
