PCB TERMINAL BLOCKS
PCB
TERMINAL
BLOCKS
INTERCONNECTION
FUSES &
FUSEHOLDERS
7.5mm & 7.62mm Pitch Pluggable Rising Clamp Terminal Blocks
• 2-12 pole solid block
• Pluggable male-female
connectors
• Open & closed headers
• Horizontal female plug style
• Polarised mouldings
• Moulded in green UL94-V0
flame retardant PA
• Professional rising
clamp terminals
• 0.2-2.5mm2 (30-12AWG)
solid & stranded cable
• Anti solder wicking
• Captive screws
• Guided pin alignment
approved
SPECIFICATION
Rating
Dielectric strength
Impulse withstand voltage
Working temperature
Moulding
Pin/terminal
Rising clamp
Screw/torque
Recommended PCB hole size
20A/500V
UL=12A/300V, VDE&IMQ=20A/500V
≥3kV
6kV
110°C
UL94-V0 flame retardant PA
Copper alloy, NI & SN
M3 steel zinc plated, 0.5Nm
ø1.4mm
LEDs &
INDICATORS
MINIATURE
SWITCHES
LIMIT &
SAFETY
SWITCHES
CONTROL
PRODUCTS
INTERFACE
MODULES &
SUPPORTS
RELAY
BASES
DIN
DIN RAIL
RAIL
ENCLOSURES
ENCLOSURES
PCB mounting male vertical (closed ended)
7.5mm
7.62mm
TYPE NO.
CTB9500/2
CTB9500/3
CTB9500/4
CTB9500/5
CTB9500/6
CTB9500/7
CTB9500/8
CTB9500/9
CTB9500/10
CTB9500/11
CTB9500/12
POLES
2
3
4
5
6
7
8
9
10
11
12
LENGTH
15mm
22.5mm
30mm
37.5mm
45mm
52.5mm
60mm
67.5mm
75mm
82.5mm
90mm
TYPE NO.
CTB9508/2
CTB9508/3
CTB9508/4
CTB9508/5
CTB9508/6
CTB9508/7
CTB9508/8
CTB9508/9
CTB9508/10
CTB9508/11
CTB9508/12
POLES
2
3
4
5
6
7
8
9
10
11
12
LENGTH
15.2mm
22.8mm
30.4mm
38.1mm
45.7mm
53.3mm
60.9mm
68.6mm
76.2mm
83.8mm
91.4mm
CTB9500
PCB mounting male horizontal (closed ended)
7.5mm
7.62mm
TYPE NO.
CTB9550/2
CTB9550/3
CTB9550/4
CTB9550/5
CTB9550/6
CTB9550/7
CTB9550/8
CTB9550/9
CTB9550/10
CTB9550/11
CTB9550/12
POLES
2
3
4
5
6
7
8
9
10
11
12
LENGTH
15mm
22.5mm
30mm
37.5mm
45mm
52.5mm
60mm
67.5mm
75mm
82.5mm
90mm
TYPE NO.
CTB9558/2
CTB9558/3
CTB9558/4
CTB9558/5
CTB9558/6
CTB9558/7
CTB9558/8
CTB9558/9
CTB9558/10
CTB9558/11
CTB9558/12
POLES
2
3
4
5
6
7
8
9
10
11
12
LENGTH
15.2mm
22.8mm
30.4mm
38.1mm
45.7mm
53.3mm
60.2mm
68.5mm
76.2mm
83.8mm
91.4mm
CTB9550
BATTERIES
SOLAR
TRANSPANELS
FORMERS
TRANSFORMERS
56
Ver
Ver1.0
1.2
We operate a constant improvement policy,
We operate
a constant
improvement
our products
are subject
to change
withoutpolicy,
notice.
our products are subject to change without notice.
(0)1638 716101
+44+44
(0)1638
716101
+44 (0)1638 716101
info@camdenboss.com
info@camdenboss.com
info@camdenboss.com
www.camdenboss.com
www.camdenboss.com
www.camdenboss.com
PCB TERMINAL BLOCKS
PCB mounting male vertical (open ended)
7.5mm
TYPE NO.
CTB9500/2AO
CTB9500/3AO
CTB9500/4AO
CTB9500/5AO
CTB9500/6AO
CTB9500/7AO
CTB9500/8AO
CTB9500/9AO
CTB9500/10AO
CTB9500/11AO
CTB9500/12AO
POLES
2
3
4
5
6
7
8
9
10
11
12
LENGTH
13mm
20.5mm
28mm
35.5mm
43mm
50.5mm
58mm
65.5mm
73mm
80.5mm
88mm
7.62mm
TYPE NO.
CTB9508/2AO
CTB9508/3AO
CTB9508/4AO
CTB9508/5AO
CTB9508/6AO
CTB9508/7AO
CTB9508/8AO
CTB9508/9AO
CTB9508/10AO
CTB9508/11AO
CTB9508/12AO
CTB9500/A0
POLES
2
3
4
5
6
7
8
9
10
11
12
LENGTH
13.2mm
20.9mm
28.5mm
36.1mm
43.7mm
51.3mm
59mm
66.6mm
74.2mm
81.8mm
89.4mm
PCB
TERMINAL
BLOCKS
INTERCONNECTION
FUSES &
FUSEHOLDERS
LEDs &
INDICATORS
PCB mounting male horizontal (open ended)
7.5mm
7.62mm
TYPE NO.
CTB9550/2AO
CTB9550/3AO
CTB9550/4AO
CTB9550/5AO
CTB9550/6AO
CTB9550/7AO
CTB9550/8AO
CTB9550/9AO
CTB9550/10AO
CTB9550/11AO
CTB9550/12AO
POLES
2
3
4
5
6
7
8
9
10
11
12
LENGTH
13mm
20.5mm
28mm
35.5mm
43mm
50.5mm
58mm
65.5mm
73mm
80.5mm
88mm
TYPE NO.
CTB9558/2AO
CTB9558/3AO
CTB9558/4AO
CTB9558/5AO
CTB9558/6AO
CTB9558/7AO
CTB9558/8AO
CTB9558/9AO
CTB9558/10AO
CTB9558/11AO
CTB9558/12AO
POLES
2
3
4
5
6
7
8
9
10
11
12
LENGTH
13.2mm
20.9mm
28.5mm
36.1mm
43.7mm
51.3mm
59mm
66.6mm
74.2mm
81.8mm
89.4mm
MINIATURE
SWITCHES
CTB9550/A0
LIMIT &
SAFETY
SWITCHES
CONTROL
PRODUCTS
INTERFACE
MODULES &
SUPPORTS
RELAY
BASES
DIN RAIL
ENCLOSURES
BATTERIES
SOLAR
PANELS
TRANSFORMERS
+44 (0)1638 716101
+44 (0)1638 716101
info@camdenboss.com
info@camdenboss.com
www.camdenboss.com
www.camdenboss.com
Ver 1.1
products
are subject
to change without
Weour
operate
a constant
improvement
policy, notice. Ver 1.0
57
很抱歉,暂时无法提供与“CTB9500/3”相匹配的价格&库存,您可以联系我们找货
