CTBP0355/3
CTBP0355/3
    CAMDENBOSS
    CAMDENBOSS - CTBP0355/3 - Wire-To-Board Terminal Block, 3.5 mm, 3 Ways, 24 AWG, 18 AWG, 1 mm², Screw
CTBP0355/3 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 3.5mm low profile 90° wire protector terminal blocks Product overview 081 TERMINAL STRIPS CTBP0355 • • • • • • • • • 2-12 pole interlocking 4-12 pole pre-assembled Ultra low profile Moulded in green UL94-V0 flame retardant PA Wire protector terminals 0.5-1.0mm2 (24-18AWG) cable Captive screws Guided pin alignment Double interlock mechanism for increased strength • C approved US , 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS POLES LENGTH UL=10A/300V, VDE=10A/250V CTBP0355/2 2 7mm Dielectric strength ≥1.25kV CTBP0355/3 3 10.5mm Impulse withstand voltage CTBP0355/4 4 14mm 2.0kV CTBP0355/5 5 17.5mm Working temperature -40°C to +105°C CTBP0355/6 6 21mm Moulding UL94-V0 flame retardant PA66 CTBP0355/7 7 24.5mm Pin/terminal Tinned, nickel plated brass CTBP0355/8 8 28mm Rising clamp Tinned, nickel plated brass CTBP0355/9 9 31.5mm Screw/torque M2 steel zinc plated, 0.2Nm CTBP0355/10 10 35mm CTBP0355/11 11 38.5mm CTBP0355/12 12 42mm Recommended PCB hole size ø1.3mm 2.28 3.5(xx-1) 3.50 3.5(xx-1) 2.10 PA R T N O . Ø1 .0 1.75 158 Ø0.80 8.40 0 INTERFACE MODULES AND RELAY BASES PCB layout 0.43 3.5xx 0.53 8.40 Rating 3.50±0.3 2.1±0.3 S P E C I F I C AT I O N 6.80 K E Y F E AT U R E S | Wire protector terminals CONNECT Ultra low profile | Double interlock mechanism +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers 21 15
CTBP0355/3 价格&库存
很抱歉,暂时无法提供与“CTBP0355/3”相匹配的价格&库存,您可以联系我们找货
