SCREWLESS
PLUGGABLES
S TA N D A R D
P C B T E R M I N A L B LO C KS
002
PCB TERMINAL
BLOCKS
6.35mm pitch high power rising
clamp terminal blocks
Product overview
081
TERMINAL STRIPS
CTBP04VY
• 2 and 3 pole double interlocking
mechanism for increased strength
• Professional rising clamp terminals
• High profile
• Moulded in green UL94-V0 flame
retardant PA66
• Cable acceptance - 0.4-2.6mm2 (2610AWG)
• 32A 450V
• Guided pin alignment
• Turret design meets requirements of IP2X
• C
approved
US ,
Insulation resistance
500M Ω/500V
Withstand voltage
AC2000V/1min
Contact resistance
20mΩ (max)
Working temperature
Moulding
Pin/terminal
Rising clamp
Screw/torque
Recommended PCB
hole size
-40°C to +105°C
UL94-V0 flame retardant PA66
Tin plated brass
Brass, nickel plated
M3 steel, zinc plated 0.5Nm
ø1.5mm
PA R T N O .
POLES
LENGTH
CTBP04VY/2
2
12.7mm
CTBP04VY/3
3
19.1mm
CTBP04VY/4
4
25.4mm
CTBP04VY/5
5
31.8mm
CTBP04VY/6
6
38.1mm
CTBP04VY/7
7
44.5mm
CTBP04VY/8
8
50.8mm
CTBP04VY/9
9
57.2mm
CTBP04VY/10
10
63.5mm
CTBP04VY/11
11
69.9mm
CTBP04VY/12
12
76.2mm
0.55
158
12.7
UL=30A/300V,
VDE=32A/450V
151
IP68 CONNECTORS
INTERFACE
MODULES AND
RELAY BASES
21.5
Rating
100
CIRCULAR
CONNECTORS
4.75
S P E C I F I C AT I O N
095
WIRE TO BOARD
CONNECTORS
6.35
1
K E Y F E AT U R E S
| Double interlock mechanism
CONNECT
High powered 32A
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
37
很抱歉,暂时无法提供与“CTBP04VY/2”相匹配的价格&库存,您可以联系我们找货
