SCREWLESS
PLUGGABLES
S TA N D A R D
P C B T E R M I N A L B LO C KS
002
PCB TERMINAL
BLOCKS
9.5mm pitch high power rising
clamp terminal blocks
Product overview
081
TERMINAL STRIPS
CTBP04VZ
• 2 and 3 pole double interlocking
mechanism for increased strength
• Professional rising clamp terminals
• High profile
• Moulded in green UL94-V0
flame retardant PA66
• Cable acceptance - 0.13-5.26mm2 (2610AWG)
• Guided pin alignment
• 32A 630V
• C
approved
US ,
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
Insulation resistance
Withstand voltage
500M Ω/500V
AC2000V/1min
Contact resistance
20mΩ (max)
Working temperature
-40°C to +105°C
Moulding
Pin/terminal
Rising clamp
Screw/torque
Recommended PCB
hole size
UL94-V0 flame retardant PA66
Tin plated brass
Brass, nickel plated
M3 steel, zinc plated 0.5Nm
ø1.6mm
PA R T N O .
POLES
LENGTH
CTBP04VZ/2
2
19.0mm
CTBP04VZ/3
3
28.5mm
CTBP04VZ/4
4
38.0mm
CTBP04VZ/5
5
47.5mm
CTBP04VZ/6
6
57.0mm
CTBP04VZ/7
7
66.5mm
CTBP04VZ/8
8
76.0mm
CTBP04VZ/9
9
85.5mm
CTBP04VZ/10
10
95.0mm
CTBP04VZ/11
11
104.5mm
CTBP04VZ/12
12
114.0mm
158
0.6
INTERFACE
MODULES AND
RELAY BASES
21
Rating
UL=30A/300V,
VDE=32A/630V
4.5
S P E C I F I C AT I O N
12.6
IP68 CONNECTORS
9.5
4.75
5.25
K E Y F E AT U R E S
| Double interlock mechanism
CONNECT
High power 32A
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
45
很抱歉,暂时无法提供与“CTBP04VZ/2”相匹配的价格&库存,您可以联系我们找货
