CTBP9308/6FL
CTBP9308/6FL
    CAMDENBOSS
    CAMDENBOSS - CTBP9308/6FL - Terminal Block, Header, 5.08 mm, 6 Ways, 20 A, 450 V, Through Hole Verti...
CTBP9308/6FL 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 5.08mm pitch pluggable rising clamp t e r m i n a l b l o c k s w i t h s c r ew f l a n g e s Product overview • • • • • • • • • • • 081 TERMINAL STRIPS S P E C I F I C AT I O N 2-12 pole solid block Professional rising clamp terminals Moulded in green UL94-V0 flame retardant PA66 Cable acceptance - 0.32 to 1.6mm2 (28-14AWG) solid and stranded cable Pluggable male and female connectors Screw flanges Horizontal female plug styles Polarised mouldings Anti solder wicking Captive screws and guided pin alignment approved US , C Rating 20A/450V UL=15A/300V, VDE and IMQ=20A/450V Dielectric strength 0.5kV Impulse withstand voltage 2kV Working temperature -40°C to 105°C Moulding UL94-V0 flame retardant PA66 Pin/terminal Copper alloy, NI and SN Rising clamp Copper alloy, NI and SN Screw/torque M3 steel zinc plated, 0.5Nm Recommended PCB hole size ø1.7mm 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS Female connector 2 20.3mm CTBP9208/3FL 3 25.4mm CTBP9208/4FL 4 30.5mm CTBP9208/5FL 5 35.6mm CTBP9208/6FL 6 40.7mm CTBP9208/7FL 7 45.7mm CTBP9208/8FL 8 50.8mm CTBP9208/9FL 9 55.9mm CTBP9208/10FL 10 60.0mm CTBP9208/11FL 11 66.1mm CTBP9208/12FL 12 71.1mm 5.08xx 5.0xx 5.08 5.0 INTERFACE MODULES AND RELAY BASES 18.00 5.30 A 8.70 5.08 5.0 3.75 CTBP9208/2FL 158 CTBP9208 FL 5.08 5.0 2.80 5.80 LENGTH 15.10 POLES A Section A-A Ø3 .0 0 PA R T N O . 0 .6 Ø1 Female vertical connector (standard) 20.3mm CTBP9308/3FL 3 25.4mm CTBP9308/4FL 4 30.5mm CTBP9308/5FL 5 35.6mm CTBP9308/6FL 6 40.7mm CTBP9308/7FL 7 45.7mm CTBP9308/8FL 8 50.8mm CTBP9308/9FL 9 55.9mm CTBP9308/10FL 10 61.0mm CTBP9308/11FL 11 66.1mm CTBP9308/12FL 12 71.1mm CTBP9308 FL 5.08 5.0 12.00 *4.00±0.30 A 7.70 8.50 LENGTH 2 1.00 A Section A-A 1.00 POLES CTBP9308/2FL 5.08 5.00 8.50 3.75 PA R T N O . Ø1 .7 Female vertical connector (reversed) 20.3mm CTBP9358/3FL 3 25.4mm CTBP9358/4FL 4 30.5mm CTBP9358/5FL 5 35.6mm CTBP9358/6FL 6 40.7mm CTBP9358/7FL 7 45.7mm CTBP9358/8FL 8 50.8mm CTBP9358/9FL 9 55.9mm CTBP9358/10FL 10 61.0mm CTBP9358/11FL 11 66.1mm CTBP9358/12FL 12 71.1mm CTBP9358 FL 5.08 5.0 12.00 A 1.00 1.00 A Section A-A 5.08 5.00 Ø1.7 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 CONNECT LENGTH 2 *4.00±0.30 7.70 8.50 POLES CTBP9358/2FL 12.00 2.00 PA R T N O . 73 P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS 002 PCB TERMINAL BLOCKS 081 TERMINAL STRIPS 5.08mm DIN rail mounted inverted/ reverse terminal blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS • • • • • • • • S P E C I F I C AT I O N Horizontal orientations Polarized moldings Can be reversed on DIN clips Also available in 5.08mm pitch Molded in green UL94-V0 flame retardant PA 66 2.5mm2 (28-14AWG) approved US , C 6-12 poles standard (13-24 also available) Rating UL=15A/300V IEC 20A/450V Insulation resistance 500MΩ/500V Withstand Voltage AC2000V/1min Contact Resistance 20mΩ (max) Working Temperature -40°C to 105+°C Mouldings UL94-V0 Flame retardant PA66 Pin/Terminal Brass, Tin plated Rising Clamp Brass, nickel plated Screw/Torque M3 Steel, zinc plated 0.5Nm 151 IP68 CONNECTORS DIN rail mounting male vertical INTERFACE MODULES AND RELAY BASES PA R T N O . POLES LENGTH CTBPD96VJ/6 6 32.0mm CTBPD96VJ/7 7 37.1mm CTBPD96VJ/8 8 42.2mm CTBPD96VJ/9 9 47.2mm CTBPD96VJ/10 10 52.3mm CTBPD96VJ/11 11 57.4mm CTBPD96VJ/12 12 62.5mm CTBPD96VJ 20.6 32 5.08 17.3 17.3 33.9 16.5 11.6 3.6 158 42.5 11.6 20.6 DIN rail mounting male vertical flanged LENGTH B 41.8mm CTBPD96VJ/7FL 7 37.1mm 46.9mm CTBPD96VJ/8FL 8 42.2mm 52.0mm CTBPD96VJ/9FL 9 47.2mm 57.0mm CTBPD96VJ/10FL 10 52.3mm 62.1mm CTBPD96VJ/11FL 11 57.4mm 67.2mm CTBPD96VJ/12FL 12 62.5mm 72.3mm CTBPD96VJ/FL Length B Length A 20.6 17.3 33.9 LENGTH A 32.0mm 21.5 12.3 11.6 3.6 POLES 6 5.08 PA R T N O . CTBPD96VJ/6FL 42.5 11.6 20.6 CONNECT DIN rail mounting male horizontal 74 POLES LENGTH CTBPD96HJ/6 6 32.0mm CTBPD96HJ/7 7 37.1mm CTBPD96HJ/8 8 42.2mm CTBPD96HJ/9 9 47.2mm CTBPD96HJ/10 10 52.3mm CTBPD96HJ/11 11 57.4mm CTBPD96HJ/12 12 62.5mm CTBPD96HJ 19.2 31.8 5.08 20.5 32.6 PA R T N O . We operate a constant improvement policy, our products are subject to change without notice. Vers 1 20.2 12.3 11.6 8.5 11.6 42.5 19.2 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com 1
CTBP9308/6FL 价格&库存
很抱歉,暂时无法提供与“CTBP9308/6FL”相匹配的价格&库存,您可以联系我们找货
