P C B T E R M I N A L B LO C KS
S TA N D A R D
PLUGGABLES
SCREWLESS
002
PCB TERMINAL
BLOCKS
081
TERMINAL STRIPS
5 .0 8 m m i nve r te d /reve r s e te r m i n a l
blocks
Product overview
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
S P E C I F I C AT I O N
2-12 pole solid block
Professional rising clamp terminals
Moulded in green UL94-V0 flame retardant PA 66
Cable acceptance - 0.32 to 1.6mm2 (28-14AWG)
Horizontal and vertical orientations
Pluggable male and female connectors
Polarized moulding
Dual row pins for extra stability
Also available in 5mm pitch
US approved
C
151
Rating
UL=15A/300V
Insulation resistance
500M Ω/500V
Withstand voltage
AC2000V/1min
Contact resistance
20mΩ (max)
Working temperature
-40°C to +105°C
Moulding
UL94-V0 flame retardant PA66
Pin/terminal
Tin plated brass
Rising clamp
Brass, nickel plated
Screw/torque
M3 steel, zinc plated 0.5Nm
Recommended PCB hole size
ø1.4mm
IP68 CONNECTORS
Male connector
PA R T N O .
POLES
LENGTH
CTBP96HJ/2
2
11.8mm
CTBP96HJ/3
3
16.8mm
CTBP96HJ/4
4
21.9mm
CTBP96HJ/5
5
27.0mm
CTBP96HJ/6
6
32.1mm
CTBP96HJ/7
7
37.2mm
CTBP96HJ/8
8
42.2mm
CTBP96HJ/9
9
47.3mm
CTBP96HJ/10
10
52.4mm
CTBP96HJ/11
11
57.5mm
CTBP96HJ/12
12
62.6mm
CTBP96HJ
5.08
8.6
19.30
INTERFACE
MODULES AND
RELAY BASES
9.4
158
15.2
Male connector (flanged)
LENGTH
A
LENGTH
B
CTBP96HJ/2FL
2
11.8mm
20.3mm
CTBP96HJ/3FL
3
16.8mm
25.4mm
CTBP96HJ/4FL
4
21.9mm
30.5mm
CTBP96HJ/5FL
5
27mm
35.6mm
CTBP96HJ/6FL
6
32.1mm
40.7mm
CTBP96HJ/7FL
7
37.2mm
45.7mm
CTBP96HJ/8FL
8
42.2mm
50.8mm
CTBP96HJ/9FL
9
47.3mm
55.9mm
CTBP96HJ/10FL
10
52.4mm
61.0mm
CTBP96HJ/11FL
11
57.5mm
66.1mm
CTBP96HJ/12FL
12
62.6mm
71.1mm
B
CTBP96HJ FL
A
5.08
5.08
5.08
8.60
19.30
POLES
9.40
PA R T N O .
15.20
72
CTBP97VJ/2
2
12.2mm
CTBP97VJ/3
3
17.2mm
CTBP97VJ/4
4
22.3mm
CTBP97VJ/5
5
27.4mm
CTBP97VJ/6
6
32.5mm
CTBP97VJ/7
7
37.6mm
CTBP97VJ/8
8
42.6mm
CTBP97VJ/9
9
47.7mm
CTBP97VJ/10
10
52.8mm
CTBP97VJ/11
11
57.9mm
CTBP97VJ/12
12
63.0mm
CTBP97VJ
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
10.2
4
8.3
LENGTH
19
POLES
8.5
PA R T N O .
5.08
3.6
CONNECT
PCB mounted female vertical connector
5.08
1.36
SCREWLESS
PLUGGABLES
S TA N D A R D
002
PCB TERMINAL
BLOCKS
PCB mounting female vertical connector (flanged)
CTBP97VJ/2FL
2
10.2mm
20.32mm
CTBP97VJ/3FL
3
15.2mm
25.4mm
CTBP97VJ/4FL
4
20.3mm
30.48mm
CTBP97VJ/5FL
5
25.4mm
35.56mm
CTBP97VJ/6FL
6
30.5mm
40.64mm
CTBP97VJ/7FL
7
35.6mm
45.72mm
CTBP97VJ/8FL
8
40.6mm
50.8mm
CTBP97VJ/9FL
9
45.7mm
55.88mm
CTBP97VJ/10FL
10
50.8mm
60.96mm
CTBP97VJ/11FL
11
55.9mm
66.04mm
CTBP97VJ/12FL
12
61.0mm
71.12mm
CTBP97VJ FL
5.08
5.08
081
TERMINAL STRIPS
10.2
A
4
8.3
LENGTH
B
5.08
5.08
1.36
151
3
17.2mm
CTBP97HJ /4
4
22.3mm
CTBP97HJ /5
5
27.4mm
CTBP97HJ /6
6
32.5mm
CTBP97HJ /7
7
37.6mm
CTBP97HJ /8
8
42.6mm
CTBP97HJ /9
9
47.7mm
CTBP97HJ /10
10
52.8mm
CTBP97HJ /11
11
57.9mm
CTBP97HJ /12
12
63.0mm
5.08
158
INTERFACE
MODULES AND
RELAY BASES
10.2
8.3
CTBP97HJ /3
CTBP97HJ
1.1 5.08
12.2mm
19
LENGTH
2
IP68 CONNECTORS
8.5
POLES
CTBP97HJ /2
100
CIRCULAR
CONNECTORS
B
PCB mounting female horizontal connector
PA R T N O .
095
WIRE TO BOARD
CONNECTORS
19
LENGTH
A
3.6
POLES
8.5
PA R T N O .
PCB mounting female horizontal connector (flanged)
10.2mm
20.32mm
CTBP97HJ/3FL
3
15.2mm
25.4mm
CTBP97HJ/4FL
4
20.3mm
30.48mm
CTBP97HJ/5FL
5
25.4mm
35.56mm
CTBP97HJ/6FL
6
30.5mm
40.64mm
CTBP97HJ/7FL
7
35.6mm
45.72mm
CTBP97HJ/8FL
8
40.6mm
50.8mm
CTBP97HJ/9FL
9
45.7mm
55.88mm
CTBP97HJ/10FL
10
50.8mm
60.96mm
CTBP97HJ/11FL
11
55.9mm
66.04mm
CTBP97HJ/12FL
12
61.0mm
71.12mm
5.08
5.08
5.08
10.2
A
B
CONNECT
2
2.8 5.08
CTBP97HJ/2FL
CTBP97HJ FL
8.3
LENGTH
B
19
LENGTH
A
8.5
POLES
2.8
PA R T N O .
Vers 1
73
很抱歉,暂时无法提供与“CTBP96HJ/8”相匹配的价格&库存,您可以联系我们找货
