CTBPDDVG/2
CTBPDDVG/2
    CAMDENBOSS
    Conn Terminal Block F 4 POS 5mm Solder ST Thru-Hole 15A
CTBPDDVG/2 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS 002 PCB TERMINAL BLOCKS 081 TERMINAL STRIPS 5mm double decker rising clamp terminal blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS CTBPDDVG • Double  interlocking mechanism for increased strength • Double decker • Moulded in green UL94-V0 flame retardant PA66 • 2.5mm2 - IEC • 30-14 AWG - UL • Professional rising clamp terminals • Guided pin alignment • C approved US , 151 AC2000V/1min Contact resistance 20mΩ (max) Working temperature -40°C to +105°C Moulding UL94-V0 flame retardant PA66 Pin/terminal Rising clamp Tin plated brass Brass, nickel plated Screw/torque M2.5 steel, zinc plated 0.4Nm Recommended PCB hole size ø1.5mm LENGTH 4 12.5mm CTBPDDVG/3 6 17.5mm CTBPDDVG/4 8 22.5mm CTBPDDVG/5 10 27.5mm CTBPDDVG/6 12 32.5mm CTBPDDVG/7 14 37.5mm CTBPDDVG/8 16 42.5mm CTBPDDVG/9 18 47.5mm CTBPDDVG/10 20 52.5mm CTBPDDVG/11 22 57.5mm CTBPDDVG/12 24 62.5mm 15 15 1.60 0.80 *15.24±0.3 *5.00±0.08 K E Y F E AT U R E S CONNECT Double decker | Double interlocking mechanism | Professional rising clamp 30 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers2.3 1 0.60 21.6 INTERFACE MODULES AND RELAY BASES Withstand voltage POLES CTBPDDVG/2 10 158 500M Ω/500V PA R T N O . 12.6 Insulation resistance UL=15A/300V VDE=18A/250V 14 Rating *3.50±0.08 S P E C I F I C AT I O N 25.2 IP68 CONNECTORS 2.50 0.90 0.60 2.50 5.0XX 0.60
CTBPDDVG/2 价格&库存
很抱歉,暂时无法提供与“CTBPDDVG/2”相匹配的价格&库存,您可以联系我们找货
