BIM2005/15-WH/CLR
BIM2005/15-WH/CLR
    CAMDENBOSS
BIM2005/15-WH/CLR 数据手册
UNIVERSAL ENCLOSURES 2000 Clear Lid UNIVERSAL ENCLOSURES hand held cases heavy duty enclosures DIN Rail Boxes Interface supports Extensive range of electronic enclosures for applications that require visible electronics such as LED's or meters. Specification Materials Operating Temperature Protection class Standard colours Standard unit includes • Lid moulded in transparent high impact ABS • Lid mounted by four M3 machine screws • Polished finish for ease of cleaning • Integral mounting guides to accept 1.6mm PCB's • PCB Adaptors (included) for horizontal PCB mounting Grey BIM2008/18-GY/CL BIM2000/10-GY/CL BIM2001/11-GY/CL BIM2002/12-GY/CL BIM2003/13-GY/CL BIM2007/17-GY/CL BIM2004/14-GY/CL BIM2005/15-GY/CL BIM2006/16-GY/CL Black BIM2008/18-BLK/CL BIM2000/10-BLK/CL BIM2001/11-BLK/CL BIM2002/12-BLK/CL BIM2003/13-BLK/CL BIM2007/17-BLK/CL BIM2004/14-BLK/CL BIM2005/15-BLK/CL BIM2006/16-BLK/CL ivory BIM2008/18-WH/CL BIM2000/10-WH/CL BIM2001/11-WH/CL BIM2002/12-WH/CL BIM2003/13-WH/CL BIM2004/14-WH/CL BIM2005/15-WH/CL BIM2006/16-WH/CL Base high impact ABS Lid transparent high impact ABS Resistant to temperatures of up to 85°C IP54 Grey(GY), Black(BK), Ivory(WH) Base & clear lid 4x M3 machine screws PCB adaptors Length 55mm 75mm 85mm 100mm 112mm 112mm 120mm 150mm 190mm width 55mm 50mm 56mm 50mm 62mm 62mm 65mm 80mm 110mm Height 42mm 27mm 39mm 25mm 31mm 31mm 40mm 50mm 60mm H control stations diecast & metal boxes L W Desktop & Instrument cases 2000 Lugged Lid Potting Boxes 19'' Enclosures 19'' CABINETS Development BOARDS Electronics enclosures with lugged lid, for broad range of surface mounting applications. Provides extra security once mounted by restricting access to the screws in the lid. • Lugged Lid and base moulded in ABS • Lid mounted by four M3 machine screws • Polished finish for ease of cleaning • Excellent properties for machining • Integral mounting guides to accept 1.6mm PCB's • PCB Adaptors (included) for horizontal PCB mounting Grey BIM2003/LUG-GY/GY BIM2004/LUG-GY/GY BIM2005/LUG-GY/GY Black BIM2003/LUG-BLK/BLK BIM2004/LUG-BLK/BLK BIM2005/LUG-BLK/BLK ivory BIM2003/LUG-WH/WH BIM2004/LUG-WH/WH BIM2005/LUG-WH/WH Length 132mm 140mm 172mm Specification Materials Operating Temperature Protection class Standard colours Standard unit includes width 62mm 65mm 80mm Lid & base high impact ABS Resistant to temperatures of up to 85°C IP54 Grey(GY), Black(BK), Ivory(WH) Base & lugged lid 4x M3 machine screws PCB adaptors Height 31mm 40mm 50mm H custom sized enclosures Custom Services L W 5 Ver 1.0 EL EC T RO N IC S & ENC LOSURES Iss 3 We operate a constant improvement policy, our products are subject to change without notice. +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com
BIM2005/15-WH/CLR 价格&库存
很抱歉,暂时无法提供与“BIM2005/15-WH/CLR”相匹配的价格&库存,您可以联系我们找货
