CBEAC-02-WH
CBEAC-02-WH
    CAMDENBOSS
    CAMDENBOSS - CBEAC-02-WH - Plastic Enclosure, Multipurpose, ABS, 45 mm, 70 mm, 110 mm, IP40
CBEAC-02-WH 数据手册
U N I V E R SA L E N C LOS U R E S Call our sales team on 01638 716101 or visit marketing.camdenboss.com/easy-assembly-electronics-enclosures Easy Assembly Electronics enclosure Product overview This UK manufactured universal enclosure has been designed to provide flexibility and increased functionality. A unique, dual action lid and clip-in-points for your PCB, reduces assembly time whilst providing the end user with a premium quality, modern product. Moulded from ABS UL94-V0 material, in a variety of sizes and colours, with optional DIN Rail / wall mount brackets available. If you need an enclosure that can handle generic electronic applications whilst looking good, then look no further! Dual action lid Key features The dual action lid is held in place with a push-button clip or with a single screw. Spring feature in lid Holds the PCB securely in place without the need for screws, greatly improving the assembly time. No corner pillars Maximised PCB footprint, providing edge-to-edge capability. PCB edge corner supports in the base Sizes 3 & 4 have four additional half board supports which can be removed to make way for solder points on the bottom of the PCB. Multiple PCB mounting points in base and lid Central position mounting bosses support edge-to-edge capability. Suitable for 3mm x 6mm screws. Smooth finish All sides of the enclosure have been designed to have a smooth finish for ease of customisation and modification. Raspberry Pi compatible Sizes 3 & 4 fit Raspberry Pi 3 and 4 and Size 1 fits the Raspberry Pi Zero. PCB positions C P L AST I C E N C LOS U R E S A 01 B B B A C A D I M E N S I O N S F O R E AC H E N C LO S U R E S I Z E E N C LO S U R E SIZE SIZE 1 PCB MOUNTING POSITION BASE LID SIZE 2 BASE LID SIZE 3 BASE LID SIZE 4 BASE LID MAX PCB DIMENSIONS B OA R D T H I C K N E S S A Lower Screw Mounted 82mm x 52mm (end connector) / 80.5mm (side connectors) Any B Upper Captivated 84mm x 53mm 0.8 to 1.8mm C Four Screw Mounts 68mm x 54mm Any A Lower Screw Mounted 101.5mm x 61.5mm (end connector) / 100.5mm (side connector) Any B Upper Captivated 104mm x 63mm 0.8 to 1.8 mm C Four Screw Mounts 89mm x 61.5mm Any A Lower Screw Mounted Full board 121.5mm x 71.5mm (end connector) / 121mm (side connector) Any A Lower Screw Mounted Half Board 71.5mm x 45.3mm (central pillars) / 60.25mm (off centre pillars) Any B Upper Captivated 124mm x 73mm 0.8 to 1.8mm C Four Screw Mounts 109mm x 71.5mm Any A Lower Screw Mounted Full Board 141mm x 81mm (end connector & side connector) Any A Lower Screw Mounted Half Board 81mm x 44.8mm (centre pillars) / 70mm (off centre pillars) Any B Upper Captivated 144mm x 83mm 0.8 to 1.8mm C Four Screw Mounts 129mm x 81mm Any +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 U N I V E R SA L E N C LOS U R E S Call our sales team on 01638 716101 or visit marketing.camdenboss.com/easy-assembly-electronics-enclosures Easy Assembly Electronics enclosure I N D I V I D U A L S I Z E S P E C I F I C AT I O N E N C LO S U R E SIZE GREY (GY) B L AC K ( B K ) WHITE (WH) EXTERNAL DIMENSIONS (LXWXH) INTERNAL DIMENSIONS (LXWLH) WA L L T H I C K N E S S Size 1 CBEAC-01-GY CBEAC-01-BK CBEAC-01-WH 90mm x 60mm x 40mm 82mm x 52mm x 36mm 2.5mm Size 2 CBEAC-02-GY CBEAC-02-BK CBEAC-02-WH 110mm x 70mm x 45mm 101.5mm x 61.5mm x 41mm 2.5mm Size 3 CBEAC-03-GY CBEAC-03-BK CBEAC-03-WH 130mm x 80mm x 45mm 121.5mm x 71.5mm x 41mm 2.5mm Size 4 CBEAC-04-GY CBEAC-04-BK CBEAC-04-WH 150mm x 90mm x 50mm 144mm x 83mm x 46mm 2.5mm R A N G E S P E C I F I C AT I O N STANDARD UNIT INCLUDES MATERIALS COLOURS UL94-V0 ABS Lid UL94-V0 ABS/ brass M3 insert Screw Bright Zinc Plated Steel Grey RAL7047 Black RAL9005 White RAL9003 RoHS compliant IP RATING IP40 OPERATING TEMPERATURE -10°C to 80°C SCREW TORQUE PURCHASING INFORMATION P L AST I C E N C LOS U R E S Base COMPLIANCE TEST RESULTS 01 Base, lid and one M3 screw (Pozi Pan BZP) L W Standard Test Result Test report EN62262 Impact test IK06 TR106 UL94 Flammability V0 E115797 0.5Nm Data logging, fire sensors, solar controllers, Country of origin Great Britain (GB) DIN Rail electronics, environmental monitoring, Commodity code 39231010 desktop instruments, production equipment, solar Weight Size 1 619g Size 2 849g Size 3 1079g Size 4 1289g Universal For different colours and materials MOQs will apply Accessories controllers, IoT equipment, speakers and audible indication and much more... Customisation options Digital printing, screen printing, machining / drilling and engraving. DIN Rail Mount Bracket (CDR-Bracket) Universal Wall Mount Bracket (CBWM-10xx) +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 Potential industries / applications M3 screw (Pozi Pan) Enclosure type OPTIONS H
CBEAC-02-WH 价格&库存
很抱歉,暂时无法提供与“CBEAC-02-WH”相匹配的价格&库存,您可以联系我们找货
