CCA1P1/A03
CCA1P1/A03
    CAMDENBOSS
    Circular Connector, IP68, Shielded, CamCirc CCA Series, Cable Mount Plug, 3 Contacts, Solder Pin
CCA1P1/A03 数据手册
CIRCULAR CONNECTORS PLUGS SOCKETS ACC E SS O R I E S 002 PCB TERMINAL DIECAST BLOCKS ACCESSORIES 081 TERMINAL STRIPS 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS Push-pull connectors cable mounted plug CCA1 series C C A 1 P 1 /A 0 3 3 pole CCA1P1/A03 • Premium range of circular connectors • IP68 sealed using vacuum technology (when connected and using environmental cable clamp) • Tough, high performance interconnection solution • Ideal for harsh and extreme environments • Suitable for broadcasting, autosport, military, rail, marine, security, industrial and agricultural applications • Key coded to prevent misconnection • Will not disconnect when the cable is under load or stress • Tested to IEC 60512-3-5a S P E C I F I C AT I O N PA R T N O . DESCRIPTION POLES SERIES CCA1P1/A03 Cable mounted plug 3 CCA series 158 INTERFACE MODULES AND RELAY BASES ~36 9.3 Ø5.2 ~26 7 8 Shell style/model Cable mounted straight plug, male contact Codes Code 1 Contact type Solder type Contact diameter 0.9mm Max. stranded conductor AWG 21-22 Max diameter 0.79mm Vtest (contact-shell) 1300V(AC) 1800V(DC) Vtest (contactcontact) 1300V(AC) 1600V(DC) Rated current 8.2A Rated voltage ≤250V Mechanical operation 5000 mating cycles Housing material Brass (natural chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Insulator PPS Contacts Brass (gold plated) Humidity (max) 72 hr Climatical category 50/175/21 Shielding (min) 75 dB (10 MHz) Shielding (min) 40 dB (1 GHz) IP rating IP68 (when connected and using environmental cable clamp) This product should be used with the following cable clamps: PA R T N O . WIRE RANGE CCV1C/CC 2.6 - 3.1mm CCV1C/CD 3.1-3.6mm CCV1C/CE 3.6-4.1mm CCV1C/CF 4.1-4.3mm 1 Non IP68 cable clamps also available ACC E SS O R I E S Metal cap for plugs PA R T N O . DESCRIPTION CCA12 Camcirc metal cap for plug A1 A S S O C I AT E D P R O D U C T S CONNECT C C M 1 S 1 / 0 3 C B 1 S 1 / 0 3 C C E 1 S 1 / 0 3 C C T 1 S 1 / 0 3 102 -CCM -CCB -CCE -CCT series series series series A1 A1 A1 A1 size size size size s o c k e t s o c k e t s o c k e t s o c k e t page page page page 122 131 140 146 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614
CCA1P1/A03 价格&库存
很抱歉,暂时无法提供与“CCA1P1/A03”相匹配的价格&库存,您可以联系我们找货
CCA1P1/A03
  • 1+169.82886
  • 5+166.43395
库存:17
