CCT1S1/07
CCT1S1/07
    CAMDENBOSS
    CAMDENBOSS - CCT1S1/07 - Circular Connector, IP68, CamCirc CCT Series, Cable Mount Receptacle, 7 Con...
CCT1S1/07 数据手册
Multi-Pole Connectors Push-Pull Connectors Female Cable Mount Socket Part Number: CCT1S1/07 CCT Series Illustration Pole: 7 Size Drawing Insert Con�iguration Technical Data Common Values Shell Style/Model: Free cable mount socket connector, female contact Codes: Code 1 Contact Type: Solder type Contact Diameter: 0.5mm Electrical Values Max. Stranded Conductor:AWG26-28 Material Housing Material: Insulator: Brass (natural chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces PPS Contacts: Brass (Gold plated) Others Humidity (max): 72 hr Rated Current: 2.0A Climatical Category: 50/175/21 Rated Voltage: ≤160V Shielding (min): 75 dB (10 MHz) Mechanical Operation: 5000 mating cycles Shielding (min): 40 dB (1 GHz) IP Rating: 68 Vtest (contact-shell): CamdenBoss Ltd. Ver 1.2 800V(AC) 1300V(DC) www.camdenboss.com
CCT1S1/07 价格&库存
很抱歉,暂时无法提供与“CCT1S1/07”相匹配的价格&库存,您可以联系我们找货
