CCU3C/CJ
CCU3C/CJ
    CAMDENBOSS
    CAMDENBOSS - CCU3C/CJ - Circular Connector Clamp, 6.2 mm, CamCirc, CamCirc Cable Mount Plugs & Recep...
CCU3C/CJ 数据手册
SOCKETS PLUGS CIRCULAR CONNECTORS 002 PCB TERMINAL DIECAST DIECAST BLOCKS ACCESSORIES ACCESSORIES Push-pull connectors cable mounted plug CCA3 series C C A 3 P 1 /A 1 0 10 pole CCA3P1/A10 • Premium range of circular connectors • IP68 sealed using vacuum technology (when connected and using environmental cable clamp) • Tough, high performance interconnection solution • Ideal for harsh and extreme environments • Suitable for broadcasting, autosport, military, rail, marine, security, industrial and agricultural applications • Key coded to prevent misconnection • Will not disconnect when the cable is under load or stress • Tested to IEC 60512-3-5a S P E C I F I C AT I O N PA R T N O . DESCRIPTION POLES SERIES CCA3P1/A10 Cable mounted plug 10 CCA series ~48 Ø8 13 ~38 11 081 TERMINAL STRIPS Shell style/model Cable mounted straight plug, male contact Codes Code 1 Contact type Solder type Contact diameter 0.7mm Max. stranded conductor AWG 21-22 Max diameter 0.79mm Vtest (contact-shell) 1400V(AC) 2000V(DC) Vtest (contact-contact) 1500V(AC) 2200V(DC) Rated current 4.5A Rated voltage ≤250V Mechanical operation 5000 mating cycles Housing material Brass (natural chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Insulator PPS Contacts Brass (gold plated) Humidity (max) 72 hr Climatical category 50/175/21 Shielding (min) 75 dB (10 MHz) Shielding (min) 40 dB (1 GHz) IP rating IP68 (when connected and using environmental cable clamp) 11 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS 158 INTERFACE MODULES AND RELAY BASES This product should be used with the following cable clamps: PA R T N O . WIRE RANGE CCU3C/CJ 5.7 - 6.2mm CCU3C/CL 6.2 - 6.7mm Non IP68 cable clamps also available ACC E SS O R I E S Metal cap for plugs 1 PA R T N O . DESCRIPTION CCA32 Camcirc metal cap for plug A3 C C M 3 S 1 / 1 0 - C C M s e r i e s A 3 s i z e s o c k e t CONNECT A S S O C I AT E D P R O D U C T S page 128 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers 1 113
CCU3C/CJ 价格&库存
很抱歉,暂时无法提供与“CCU3C/CJ”相匹配的价格&库存,您可以联系我们找货
CCU3C/CJ
    • 1+71.78258
    • 5+64.60745
    库存:21
