CHH64E2DG
CHH64E2DG
    CAMDENBOSS
CHH64E2DG 数据手册
H A N D H E L D E N C LOS U R E S 268 HANDHELD CASES 64 Series End Cap ABS Handheld Enclosure Product overview 292 UNIVERSAL PLASTIC ENCLOSURES CHH64 Multi-purpose snap-fit handheld enclosures designed for quick assembly. 317 HEAVY DUTY AND ELECTRICAL ENCLOSURES • Moulded in high grade ABS, UL94-V0 • Lid and base snap-fit assembled via end caps • Optional battery compartment lid M3 retaining screw • Recesses in lid, base and end caps for membrane keypads or overlays • PCB pillars in lid and base • 64 series has been designed to meet the requirements of IP54 or additionally, IP65 with the optional gasket accessory 341 DEVELOPMENT BOARD ENCLOSURES 369 VERSATILE IOT AND SENSOR ENCLOSURES S P E C I F I C AT I O N B L AC K LIGHT GREY LENGTH W I DT H HEIGHT STYLE Material Base and lid high grade ABS, UL94-V0 CHH641NBK CHH641NGY 100mm 80mm 20mm - Operating temperature Resistant to temperatures of up to 80°C CHH642BBK CHH642BGY 100mm 80mm 30mm Protection class 64 series has been designed to meet the requirements of IP54 or additionally, IP65 with the optional gasket accessory Battery door CHH643NBK CHH643NGY 120mm 80mm 20mm - 64 series standard colours Top and base in grey RAL7035 and black RAL 9004 End caps-red, blue, yellow, green, orange, grey or black Custom colours available to order CHH644BBK CHH644BGY 120mm 80mm 30mm Battery door Standard unit includes Top and base (battery door and retaining screw style 2 and 4) Options End caps, battery compartments and IP65 gaskets supplied separately K E Y F E AT U R E S H i g h g ra d e A B S , U L 9 4 -V 0 | Battery compartment | PCB pillars ACC E SS O R I E S 64 series IP65 gasket PA R T N O . DESCRIPTION CHH64GASK 64 series IP65 gasket for optional battery compartment PA R T N O . DESCRIPTION CO LO U R CHHBAT1BK Clip-in battery compartment PP3 Black CHHBAT1GY Clip-in battery compartment PP3 Grey CHHBAT2BK Clip-in battery compartment AA Black CHHBAT2GY Clip-in battery compartment AA Grey P L AST I C E N C LOS U R E S Battery compartments Plastic end caps PA R T N O . CO LO U R DESCRIPTION PA R T N O . CO LO U R DESCRIPTION CHH64E1BL Blue To fit 20mm high cases CHH64E2BL Blue To fit 30mm high cases CHH64E1GR Green To fit 20mm high cases CHH64E2GR Green To fit 30mm high cases CHH64E1RD Red To fit 20mm high cases CHH64E2RD Red To fit 30mm high cases CHH64E1OR Orange To fit 20mm high cases CHH64E2OR Orange To fit 30mm high cases CHH64E1BK Black To fit 20mm high cases CHH64E2BK Black To fit 30mm high cases CHH64E1YL Yellow To fit 20mm high cases CHH64E2YL Yellow To fit 30mm high cases CHH64E1DG Grey To fit 20mm high cases CHH64E2DG Grey- To fit 30mm high cases +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 Vers 1 271
CHH64E2DG 价格&库存
很抱歉,暂时无法提供与“CHH64E2DG”相匹配的价格&库存,您可以联系我们找货
