CRDCG0002
CRDCG0002
    CAMDENBOSS
CRDCG0002 数据手册
U N I V E R SA L E N C LOS U R E S 268 HANDHELD DIECASTCASES ACCESSORIES 292 UNIVERSAL ENCLOSURES 7000 series recessed designer cases Product overview 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES 342 DESKTOP AND INSTRUMENT CASES Functional yet modern design in nine different sizes with anti-scratch finish. RFI wall mount options available. • • • • • • 348 DEVELOPMENT BOARD ENCLOSURES 367 ROOM SENSOR ENCLOSURES CRDCG0001 • • • • • Lid and base moulded in ABS Lid mounted by four M3 machine screws Plastic screw covers for aesthetic appearance Fine texture anti-scratch finish Recesses in lid and base designed to accept membrane keypads or overlays Integral mounting guides in lid and base for vertical PCB mounting PCB pillars in lid and base Surface mountable via moulded fixing points or wallmounting kit (optional) Can be supplied with optional waterproof gasket Can be supplied with optional waterproof gasket and RFI shielding 7000 series has been designed to meet the requirements of IP54 or additionally, IP65 with the gasket accessory 370 P L AST I C E N C LOS U R E S CUSTOM SIZED ENCLOSURES 294 S P E C I F I C AT I O N Materials Lid, base and screw covers ABS, UL94-V0 Operating temperature -20°C - 80°C Protection class 7000 series has been designed to meet the requirements of IP54 or additionally, IP65 with the gasket accessory Standard unit includes Base and lid 4x M3 machine screws (torque 0.5 Nm) 4x screw covers Options Wall mounting kit IP65 gasket kits RFI screening B L AC K LENGTH W I DT H HEIGHT DESCRIPTION CRDCB0001 90mm 55mm 25mm Designer case CRDCB0002 90mm 55mm 40mm Designer case CRDCB0003 110mm 85mm 35mm Designer case CRDCB0004 127mm 75mm 30mm Designer case CRDCB0005 127mm 75mm 45mm Designer case CRDCB0006 145mm 90mm 45mm Designer case CRDCB0007 190mm 120mm 60mm Designer case CRDCB0008 220mm 145mm 50mm Designer case CRDCB0009 220mm 145mm 80mm Designer case GREY LENGTH W I DT H HEIGHT DESCRIPTION CRDCG0001 90mm 55mm 25mm Designer case CRDCGG001 90mm 55mm 25mm With gasket CRDCERG01 90mm 55mm 25mm With RFI and gasket CRDCG0002 90mm 55mm 40mm Designer case CRDCGG002 90mm 55mm 40mm With gasket CRDCERG02 90mm 55mm 40mm With RFI and gasket CRDCG0003 110mm 85mm 35mm Designer case CRDCGG003 110mm 85mm 35mm With gasket CRDCERG03 110mm 85mm 35mm With RFI and gasket CRDCG0004 127mm 75mm 30mm Designer case CRDCGG004 127mm 75mm 30mm With gasket CRDCERG04 127mm 75mm 30mm With RFI and gasket CRDCG0005 127mm 75mm 45mm Designer case CRDCGG005 127mm 75mm 45mm With gasket CRDCERG05 127mm 75mm 45mm With RFI and gasket CRDCG0006 145mm 90mm 45mm Designer case CRDCGG006 145mm 90mm 45mm With gasket CRDCERG06 145mm 90mm 45mm With RFI and gasket CRDCG0007 190mm 120mm 60mm Designer case CRDCGG007 190mm 120mm 60mm With gasket CRDCERG07 190mm 120mm 60mm With RFI and gasket CRDCG0008 220mm 145mm 50mm Designer case CRDCGG008 220mm 145mm 50mm With gasket CRDCERG08 220mm 145mm 50mm With RFI and gasket CRDCG0009 220mm 145mm 80mm Designer case CRDCGG009 220mm 145mm 80mm With gasket CRDCERG09 220mm 145mm 80mm With RFI and gasket +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 EMS 613558 U N I V E R SA L E N C LOS U R E S 268 HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES ACC E SS O R I E S 292 UNIVERSAL ENCLOSURES 7000 series IP65 gasket kits • EPDM gasket, dust and water protection from IP54 to IP65 PA R T N O . DESCRIPTION CRDCGASK1 Gasket for designer case size 1 and 2 CRDCGASK2 Gasket for designer case size 3 CRDCGASK3 Gasket for designer case size 4 and 5 CRDCGASK4 gasket for designer case Size 6 CRDCGASK5 Gasket for designer case Size 7 CRDCGASK6 Gasket for designer case size 8 and 9 PA R T N O . DESCRIPTION CRDCWMKIT 4x mounting feet 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES 342 DESKTOP AND INSTRUMENT CASES Wa l l m o u n t i n g k i t • Universal design fits all sizes, available in grey • Fits lid and base, surface 1.5mm from lid or 9.5mm base 348 DEVELOPMENT BOARD ENCLOSURES 367 ROOM SENSOR ENCLOSURES 370 K E Y F E AT U R E S CUSTOM SIZED ENCLOSURES P L AST I C E N C LOS U R E S RFI & wall mount options | Anti-scratch finish | PCB mounting +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers 1 295
CRDCG0002 价格&库存
很抱歉,暂时无法提供与“CRDCG0002”相匹配的价格&库存,您可以联系我们找货
