CSTBP500/2
CSTBP500/2
    CAMDENBOSS
    CAMDENBOSS - CSTBP500/2 - Wire-To-Board Terminal Block, 5 mm, 2 Ways, 28 AWG, 16 AWG, 1.3 mm², Push ...
CSTBP500/2 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 5mm screwless terminal blocks 081 TERMINAL STRIPS Product overview S P E C I F I C AT I O N CSTBP500 • Interlocking modules • Easily breakable to desired number of poles • Guided pin alignment • Moulded in green UL94-V0 PA66 • 0.08-1.5mm2 cable (28-16AWG) • C US approved Rating 10A/300V Insulation withstand voltage AC2000V/1 min Insulation resistance 500MΩ at DC500V Operating temperature -40°C to +115°C Moulding UL94-V0 PA66 Pin/contact Tin plated phosphor bronze Recommended PCB hole size 1.2mm 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS PA R T N O . POLES LENGTH CSTBP500/2 2 11.6mm CSTBP500/3 3 16.6mm CSTBP500/4 4 21.6mm 5.00x(N-1)+6.60 158 12.60 INTERFACE MODULES AND RELAY BASES 5.00x(N-1) 26.6mm CSTBP500/6 6 31.6mm CSTBP500/7 7 36.6mm CSTBP500/8 8 41.6mm CSTBP500/9 9 46.6mm CSTBP500/10 10 51.6mm CSTBP500/11 11 56.6mm CSTBP500/12 12 61.6mm 5.00 0.50 Ø1.20 PCB LAYOUT 0.70 3.15 5.00 5.00 12.60 5 9.10 CSTBP500/5 5.00 2.90 5.00x(N-1) K E Y F E AT U R E S | Modular design CONNECT Dual row pins | Screwless actuated cage terminals +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers 2 1 85
CSTBP500/2 价格&库存
很抱歉,暂时无法提供与“CSTBP500/2”相匹配的价格&库存,您可以联系我们找货
