CTB04VZ/3
CTB04VZ/3
    CAMDENBOSS
CTB04VZ/3 数据手册
PCB TERMINAL BLOCKS INTERCONNECTION FUSES & FUSEHOLDERS LEDs & INDICATORS MINIATURE SWITCHES LIMIT & SAFETY SWITCHES 9.52mm Pitch High Power Rising Clamp Terminal Blocks • 2   & 3 pole double interlocking mechanism for increased strength • Moulded in green UL94-V0 flame retardant PA • Professional rising clamp terminals • 0.2-6.0mm2 (30-10AWG) solid & stranded cable • Guided pin alignment • Captive screws • , , approved SPECIFICATION Rating CTB04VZ Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Rising Clamp Screw/torque Recommended PCB hole size TYPE NO. CTB04VZ/2 CTB04VZ/3 CTB04VZ/4 CTB04VZ/5 CTB04VZ/6 CTB04VZ/7 CTB04VZ/8 CTB04VZ/9 CTB04VZ/10 CTB04VZ/11 CTB04VZ/12 POLES 2 3 4 5 6 7 8 9 10 11 12 LENGTH 19.04mm 28.56mm 38.08mm 47.6mm 57.12mm 66.64mm 76.16mm 85.68mm 95.2mm 104.72mm 114.24mm CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES BATTERIES SOLAR PANELS TRANSFORMERS We operate a constant improvement policy, our products are subject to change without notice. Ver 1.1 +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com 32A/630V UL=24A/300V, VDE&IMQ=32A/750V ≥3kV 6kV 110°C UL94-V0 flame retardant PA Tinned, nickel plated brass Zinc plated steel M3 steel zinc plated, 0.5Nm ø1.5mm
CTB04VZ/3 价格&库存
很抱歉,暂时无法提供与“CTB04VZ/3”相匹配的价格&库存,您可以联系我们找货
