CAMBLOCK
5mm Pitch Low Profile Rising Clamp Terminal Blocks
• 2-12 pole double Interlocking
mechanism for increased strength
• 4-12 pole solid block
and end stackable
• Moulded in green UL94-V0
flame retardant PA66
• Professional rising
clamp terminals
• 0.128mm²-1.23mm2 (26- 16AWG)
solid cable/ stranded cable
• Captive screws
• C US approved
LENGTH
10mm
15mm
20mm
25mm
30mm
35mm
40mm
45mm
50mm
55mm
60mm
10A/300V
5000M Ω/1000V
AC1500V/1min
20mΩ (max)
-33°C to 120+°C
UL94-V0 flame retardant PA66
M2.5 steel, nickel plated 0.4Nm
ø1.4mm
PCB
TERMINAL
BLOCKS
8.1
5x (p-1)
5.41
0.5
0.5
0.7
5
2.54
�1.0 - �1.1
4.05
5 xP
POLES
2
3
4
5
6
7
8
9
10
11
12
SPECIFICATION
Rating
Insulation resistance
Withstand voltage
Contact resistance
Working temperature
Mouldings
Screw/torque
Recommended PCB hole size
3.5
TYPE NO.
CTB0502/2
CTB0502/3
CTB0502/4
CTB0502/5
CTB0502/6
CTB0502/7
CTB0502/8
CTB0502/9
CTB0502/10
CTB0502/11
CTB0502/12
CTB0502
4.05
8.1
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
We operate a constant improvement
policy, our products are subject to
change without notice.
Ver 1
8.1
13
很抱歉,暂时无法提供与“CTB0502/4”相匹配的价格&库存,您可以联系我们找货
