PCB TERMINAL BLOCKS
7.62mm Pitch High Power Rising Clamp Terminal Blocks
• 2
& 3 pole double interlocking
mechanism for increased
strength
• 4-12 pole pre-assembled
• Moulded in green UL94-V0
flame retardant PA66
• Professional rising
clamp terminals
• 0.2-4.0mm2 (30-12AWG)
solid cable
• 0.2-2.5mm2 (30-12AWG)
stranded cable
• Guided pin alignment
• Captive screw
approved
SPECIFICATION
Rating
CTB07VL
Dielectric strength
Impulse withstand voltage
Working temperature
Moulding
Pin/terminal
Rising clamp
Screw/torque
Recommended PCB hole size
TYPE NO.
CTB07VL/2
CTB07VL/3
CTB07VL/4
CTB07VL/5
CTB07VL/6
CTB07VL/7
CTB07VL/8
CTB07VL/9
CTB07VL/10
CTB07VL/11
CTB07VL/12
POLES
2
3
4
5
6
7
8
9
10
11
12
LENGTH
15.2mm
22.9mm
30.5mm
38.1mm
45.7mm
53.3mm
61mm
68.6mm
76.2mm
83.8mm
91.4mm
PCB
TERMINAL
BLOCKS
24A/500V
UL=16A/300V, VDE&IMQ=24A/750V
≥3kV
6kV
110°C
UL94-V0 flame retardant PA66
Tinned, nickel plated brass
M3 steel zinc plated, 0.5Nm
ø1.5mm
INTERCONNECTION
FUSES &
FUSEHOLDERS
LEDs &
INDICATORS
MINIATURE
SWITCHES
LIMIT &
SAFETY
SWITCHES
CONTROL
PRODUCTS
INTERFACE
MODULES &
SUPPORTS
RELAY
BASES
DIN RAIL
ENCLOSURES
BATTERIES
SOLAR
PANELS
TRANSFORMERS
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
We operate a constant improvement
policy, our products are subject to
change without notice.
Ver 1.1
很抱歉,暂时无法提供与“CTB07VL/3”相匹配的价格&库存,您可以联系我们找货
